Need Help Wiring Subs!
Old Feb 16, 2008 | 11:36 PM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.45
HEy!
I have a (Kenwood KAC-8103D 1000W Class D Mono Power Amplifier (KAC8103D)), and right now im running single (Volfenhag ZX4812DVX 12" 1200 Watt Subwoofer ), and this week I am getting second sub, just like the one i already have, and i was wondering how should i wire it!!
Thanx, Alex
Old Feb 17, 2008 | 12:25 AM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: Need Help Wiring Subs!
I don't know that it would be worth it unless you get a second amp, maybe someone else will know for sure though.
Here's how I see it.
Amp: 2 ohm stable
500 watts rms @ 2 ohms
300 watts rms @ 4 ohms
Sub: dual 4 ohms
400 watts rms
You can't wire everything in parallel because it would put a 1 ohm load on your amp and it would overheat. You can have each sub's voice coils wired in parallel and then wire the two subs together in series, but you'll end up with a 4 ohm load with only 150 watts rms going to each sub. That's the only way I'm seeing right now, but it's late and I may have missed something :shrug:
Old Feb 17, 2008 | 11:40 AM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Axle/Gears: 3.45
Thanx! Thats kinda what i was thinking! Look i found this wiring diagram, and i think that would would work... http://www.crutchfield.com/learningc...2%2Dohm%5Fmono
tell me what you think about it.
Old Feb 17, 2008 | 01:11 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Yeah, that looks about right. The two voice coils of each sub are wired in series and then the two subs are wired in parallel. Only difference is that your subs are 4 ohms, so you would end up with a 4 ohm load when it's all done.
Old Feb 17, 2008 | 01:12 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That's the wrong diagram for the subs you have. You need the one for dual 4 ohm voice coil, not the dual 2 ohm. With two DVC 4 ohm subs, you can't get the 2 ohm load that amp is stable at. Sure you could wire to 4 ohms, but that would cut your power output in half.
This diagram works for your subs...
http://www.crutchfield.com/learningc...4%2Dohm%5Fmono
I agree with 87 formy on the possible impedance loads. The only combinations you can get from a pair of those subs are 1 ohm which might blow your amp (send it into protection mode at least), 4 ohm which will reduce the power by half, and 16 oms. Basically, you will either need an additional amp like the one you have or one that is 1 ohm stable and capable of providing the power requirements of both subs.
Al
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Bryan F
Aug 27, 2015 07:28 AM
