91 T/A Convertible Antenna won't go down.
Old Mar 8, 2008 | 06:54 PM
BadBilly442's Avatar
Car: 2Trans Am convertibles91/92
Transmission: Auto's
Axle/Gears: Who knows
Ok here we go again since i can't figure out how to POST lol.. i bought a 91 Convertible Trans Am. the antenna won't go down.. it goes up but i have to help it down.. i bought a new replacement antenna from GM thinking it went bad.. Installed the new one and the SAME,, wont go down.. WTF"? please help me out as it's driving me crazy.
Badbilly
Old Mar 9, 2008 | 08:16 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: 91 T/A Convertible Antenna won't go down.
Did the replacement come with a new mast or did you just install a new motor? I am not sure, but I thought the motor used a flexible strip to pull the mast down. If you just replaced the motor, the problem may be in the mast portion.
Old Mar 9, 2008 | 09:37 PM
It's a complete new unit and it does the same thing the old unit does, Goes up but won't go down.. i just don't get it,. is there a Relay? between the radio and the antenna i don't know about?
Old Mar 9, 2008 | 09:51 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
There is a relay. It is under the dash on the passenger side. I am sorry I don't have more info. Perhaps you will be able to here it clicking. It should be cheap to replace.
Old Mar 9, 2008 | 09:59 PM
MAN you are a god send i do hear a clicking under the dash when i shut the radio off.. Trust me i will find it lol.. Thank you so much..
Old Mar 9, 2008 | 10:02 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I just hope it fixes it. Post your findings.
Old Mar 9, 2008 | 10:09 PM
yeah as soon as i find out where it is, if it works i will take pictures and post them.. thanks again
Bill
Old Mar 9, 2008 | 11:05 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
On a side note - what do you use to "lube" the antenna?
Old Mar 9, 2008 | 11:07 PM
IT's brand new ! i haven't had to lube it yet. it's not dirty or anything..
Old Mar 15, 2008 | 09:54 PM
Ok i found the relay switch, it's just below the map pocket underneath the panel that says Performance suspension. 3 bolts hold it down. remove the bolts and it's right behind it.. All i did was smacked it with a screwdriver head and it started working lol.. Quick fix.. the Antenna goes up and down now.. Thanks for the help BINGO..
BadBilly
Old Mar 15, 2008 | 10:09 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Glad to hear it is fixed. It is only a matter of time before it goes out completely. It is amazing how fixing the little things can be so satisfying.
Old Apr 6, 2008 | 01:09 AM
gatorcola's Avatar
Engine: LB9 5.0 tpi
I checked out my owner's manual and it stated to periodically wipe down a fully extended antenna with mineral spirits the apply a very light sewing machine oil. I used "3 in 1"
Old Apr 8, 2008 | 07:22 AM
Ahh i wil use that too , thanks for the info
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
