Delco loc - unable to get the code
Old Apr 2, 2008 | 08:34 AM
Jeniik's Avatar
Car: 1989 Trans Am GTA, T-tops
Engine: 350 TPI, hypertech, K&N, no muffler
Transmission: th700
Axle/Gears: posi rear, that's all I know
Hello
I've been searching the message board but found nothing. I have an 89 GTA with the steering wheel controls for the radio that do not work (the assembly under the wheel with the contacts is just worn out). I know that there is a chance to get the unlock code for the radio but first I have to get the code from the radio that is then somehow (ebay) translated to the unlock code. I've been trying to push the preset buttons - several combinations including 1-4, 2-3 - but the radio is just saying LOC all the time, no change or anything. I even tried to disconnect the steeering wheel controls but still no result. The radio is with a cassette player.
What can I do to get the code? The car is in Prague which is central Europe, a bit far from any authorised Pontiac dealer ;-)
Any help will help.
And sorry for my poor english.
Old Apr 2, 2008 | 07:47 PM
PackmuleTA's Avatar
Car: 1986 T/A,91 Firebird
Engine: LG4 305, 3.1 V6
Transmission: TH700-R4 x2
Axle/Gears: 2.73,3.23
Re: Delco loc - unable to get the code
https://www.thirdgen.org/forums/car-...theftlock.html
I used it and it works
Old Apr 3, 2008 | 09:52 AM
Jeniik's Avatar
Transmission: th700
Thanx, but my problem is that I can not get the code from the radio - pressing buttons 2 and 3 for ten seconds does not work...
Old Apr 4, 2008 | 10:21 AM
Jeniik's Avatar
Transmission: th700
Some guy told me that there is some chance to get the unlock code from the VIN or serial number of the radio. Is that true?
Old Apr 4, 2008 | 09:55 PM
tendog's Avatar
I bought a radio off e-bay that was locked[ was told by seller it was unlocked]. Sent it off to these guy's http://www.radiosandmore.com/ they unlocked it. if i remeber it cost $25 plus shipping both ways.
hope this help's
Old Apr 4, 2008 | 10:11 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Do all the buttons work correctly??If you have tried too many times you will need to hook up a battery charger( just so the battery wont die) and leave the key on for 1 hour. Then try to retreive the code. Usually it will say SEC if you have done it too many times but other times it wont.
Old Apr 6, 2008 | 12:43 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Originally Posted by PackmuleTA
I got a delco cd player yesterday at the junkyard from a 1997 Pontiac sunfire.When I hooked it to power it came up LOC on the display.I did a search and found the above thread,followed the directions and within minutes I had it unlocked and working perfectly......
Old Apr 6, 2008 | 12:57 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Just take it to GM they reset the unlock code for 45 bucks. If there is a chance it's never had a personal code entered into it GM sets the code as 0001 when they are new. But like others have said radio goes into sleep mode if you have to many failed attempts.
Old Apr 7, 2008 | 04:39 AM
Jeniik's Avatar
Transmission: th700
Well, nothing helped, but I have to thank you for your time anyway. The best thing may be to repair the connectors to the steering wheel controls - But I will need the part with the pins (these pins have to touch a ring under the wheel but mine have faulty springs so they just do not work). I've been searching rockauto, summit and so on but found nothing. Is this part available somewhere? It does not seem to be repairable since the thing is just topo plastic and small ;-))
any help will help and thanx again!
Old Apr 23, 2008 | 08:44 AM
Jeniik's Avatar
Transmission: th700
The solution for me would be part number tw-63 by Standard Motor Products. This should connect the steering wheel controls to the radio again and that should mean automatic unlocking of the radio. Rockauto sells this little thing for $136...
Old May 6, 2008 | 05:52 PM
3rdgen383's Avatar
Car: 91 RS
Engine: 383 Stroker 450HP
Transmission: TH350 3500 Stall no OD
Axle/Gears: 30 Spline Axles 4:10 gears
the stealership can usually fix it.
Old May 7, 2008 | 02:06 AM
Jeniik's Avatar
Transmission: th700
I don't get it. What are you talkin about? About Pontiac dealership in Czech Republic? There is no such thing, man... ;-))
Old May 7, 2008 | 03:47 PM
ThirdGenTN's Avatar
Car: 1989 TransAm GTA
Transmission: 700R
I have a 89 GTA and had this issue when I purchased it. The dealer could not fix it; they told me that the only way was to have a working steering wheel pad and press the mute button. Mine, I have found, works intermittently and I happened to get lucky one morning when I just randomly pushed the Mute button and the loc display turned into the clock. There have been, and may be a few, of these pads for sale here in classifieds or may find on evilbay.
Just checked my owners manual and it states in the manual that that radio will not work without the steering wheel controls and the mute button is the only way from the dark side.....sorry.
Old May 7, 2008 | 05:31 PM
BigBadJohn's Avatar
Also refer to my thread I started last night in this subforum. I posted a copy of the procedure and the phone number
Old May 7, 2008 | 09:58 PM
ThirdGenTN's Avatar
Transmission: 700R
This does not work for the GTA radios; believe me, I tried everything, the key sequences that are referred to in the other thread do not work for our radios. Must have a working steering column pad....sorry, but that is the way it is for the GTA radio.
Old May 7, 2008 | 11:14 PM
BigBadJohn's Avatar
Oh. This is the procedure for the theftloc ones that came in 4th gen camaros and cavaliers etc
Old May 23, 2008 | 10:03 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Agreed, nothing will unlock the radio except the mute button on the steering wheel. Been there, done that.
Old Jun 2, 2008 | 12:41 AM
gta1989transam's Avatar
Hi maybe you can help me i just bought a radio off ebay and was told it was for an 88 or 89.
It look excatly the same but the plug for the steering wheel controls are different mine is a white plug with two wire and the new radio has a bigger female plug with 5 outpins. Iknow my pad works because i can unlock my old radio it just that one the fm keeps cuting out.
What type of plug is on your radio?
Old Jun 2, 2008 | 10:31 AM
Jeniik's Avatar
Transmission: th700
I have never seen the connectors of my radio so I just do not know. All I know is that there are 4 or 5 pins on the wire from the pad that connect to the steering column thing... That's all I know, sorry... :-(
Old Jun 2, 2008 | 08:31 PM
Engine: that I like
The one I had also used the two-wire plug.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
loud91rs
Oct 5, 2015 10:05 PM
Linson
Oct 1, 2015 09:50 PM
Luigytico09
Oct 1, 2015 08:46 AM
