Radio
Old Apr 25, 2008 | 12:45 AM
IROCNMIHEAD's Avatar
Car: 1985 IROC
Engine: LB9
Radio
Hey whats up? I tried searching for a thread with the diagrams for installing a head unit. So if any has the thread link or photos of the diagram would be most helpful. Thanks and take care thirdgen folks
Old Apr 25, 2008 | 03:55 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Radio
Check in the tech tips section.There's a good walkthrough there.
Just put a new Pioneer HU and speakers in the T/A.
What a difference !!
Old Apr 25, 2008 | 11:55 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Radio
buy a harness (8 bucks at wally world or you could spend 20 elsewhere)and just match colors...or you could hack up your factory harness. if your choice is the latter post the year of your car and ill get u your info
Old Apr 26, 2008 | 12:10 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: Radio
Don't hack up the factory harness. You will be asking for trouble in the long run. Get the adapter from wally world and do it right. If you are installing a pioneer Head unit the wiring adapter is the same color code as the pioneer wires. Cutting up the factory harness is something I highly not recommend doing. That's the quickest way to shorts and other problems. The wires are very brittle on our 20 odd year old cars.
Old Apr 28, 2008 | 06:04 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Re: Radio
If your do cut it up for whatever reason. 3rd Gen cars are one of the easiest to install an aftermarket radio in.
Constant 12V+ - Orange
Switched 12V+ - Yellow
Ground - Black
Illumination - Gray
Dimmer - Brown
Antenna Trigger - Pink
Antenna Right - Rear
Dash Speakers - 4x6
Left Front (+) - Tan
Left Front (-) - Gray
Right Front (+) - Light Green
Right Front (-) - Dark Green
Rear Speakers 6x9 Side Panels
Left Rear (+) - Brown
Left Rear (-) - Yellow
Right Rear (+) - Dark Blue
Right Rear (-) - Light Blue
Old Jan 2, 2009 | 06:45 PM
Car: 1985 IROC
Engine: LB9
Re: Radio
Ground - Black
Illumination - Gray
Dimmer - Brown
Dash Speakers - 4x6
Yeah sadly the last owner cut the wires before me, but great information and well listed thank you to all who responded.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
