Which speakers for my kicks?
Old May 21, 2008 | 10:15 PM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Hey guys, I'm going to put some speakers in my kickpanels and was wondering if you guys could point me in the right direction. At first i was thinking component, but then i found other 5.25's that should fit.
heres the components
http://www.hookedontronics.com/show_...73&brandtype=0
heres the other ones
http://www.crutchfield.com/App/Produ...s&viewAll=True
I need responses quickly b/c i wanna order tonight! thanks again
Old May 22, 2008 | 11:46 AM
BMAN90RS's Avatar
Re: Which speakers for my kicks?
anybody? please?
Old May 22, 2008 | 03:41 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I went with components in mine. However, my components are far higher end then the kickers that you are looking at. I went with the MB Quartz competition speakers with titanium tweeters and polypropylene woofers. I bought them a long time ago for about $350, but now they have gone up in price. I did go with the 6.5 inch , rather than the 5.25". I had to mount them a little bit differently into my kick panels int order to make the woofers fit.http://www.woofersetc.com/index.cfm?...roduct_ID=4195
The kick panels I use are made by q logic: http://www.qlogicenclosures.com/c-1156-ql-k1002.aspx
The system sounds incredibly clear with a complete sound picture and great sound imaging. I am running my speakers with a hand built 700W Rockford Fosgate amp.
Old May 22, 2008 | 05:03 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
if i was you i would research alil bit before you start jumping into things. if you want a decent set of components then look at the rainbow slcs they are amazing and not to expensive. then look at the pioneer rev series and the phoenix gold rsds if your going for ok and more cost effective.
Also there are other sites that are cheaper and have good customer service
www.sonicelectronix.com and www.onlinecarstereo.com check those sites out.
lastly go to www.caraudio.com and look at the message board there and do a lil research they will help you out and you can learn alot there.
Old May 22, 2008 | 05:28 PM
BMAN90RS's Avatar
thanks for the input guys, the reason im not going too high end is b/c im buying the 4 channel profile amp which is 60x4 so i was going w/ the 65 RMS peak on those kickers along w my 6x9's.
Old May 22, 2008 | 05:32 PM
asting's Avatar
the sensitivity isn't terribly good with those speakers. I'd probably save a bit more. I understand you can't get a $400 setup, but maybe just go with the 4x6s until you get more cash. Also, look locally and on ebay.
Old May 22, 2008 | 06:31 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
If you want REAL quality you will go with CDT euro 08 series but those are like 1000-1500 a set but worth every dime of it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Giocio
Oct 1, 2015 12:20 PM
tattmann
Sep 27, 2015 05:20 PM
