Static coming from speakers
Old Jun 6, 2008 | 08:30 PM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Well I finished my install today, alpine 6x9 type r's in the sails, 5.25 kicker components in the kicks powered by a 4 channel kicker amp. It sounds great but i am getting static coming from all the speakers. I checked my ground and it seems fine, all the wires are secure, i just dont know why i am getting this static, i tried searching but didnt come up w/ anything... plz help guys
Old Jun 6, 2008 | 08:49 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: Static coming from speakers
did you run the power wire and rca cables for the amp on different sides of the car?
Old Jun 6, 2008 | 08:51 PM
BMAN90RS's Avatar
RCA's are all on the drivers side, power on passengers side, do u think it could be my ground? i thought i had a good ground
Old Jun 6, 2008 | 10:08 PM
Johnx's Avatar
Car: 1990 Iroc
Engine: 383
Transmission: th350
Axle/Gears: 4.10
$5 noise filter that goes on the ground wire to the stereo doesn't hurt.
Old Jun 9, 2008 | 10:27 AM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
im having the same problem but mine started when a hooked up my sub. with just my amp and speakers i never had this problem. the sound changes with the engine speed.
Old Jun 9, 2008 | 08:20 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
As for aceman1, that's called ground loop interference. You can probably eliminate it by running a single wire from the chassis of the head unit, to the case of the amplifier. A lot of RCAs have an extra wire in the middle, and everyone thinks it's for the remote lead. It's not, it's for just this purpose.
BMAN90RS, Do you have the same symptom? Does the static go up with engine speed? If so, try the same remedy. When you say static though, I don't think that's your problem. Is it intermittent, like only when the car is running, or does it do it whether running or not?
If it does it all the time, my first choice would be to move the ground for the amplifiers. Make your own new hole, don't use an existing bolt or screw, and sand/scrape the area around the new hole you make. An area about the size of a quarter should be plenty.
Andrew6.688
Dec 13, 2015 10:59 AM
tcflint
Sep 14, 2015 04:55 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89lsc
Aug 14, 2015 04:58 PM
