instrument lights out, aftermarket stereo
Old Jul 3, 2008 | 03:50 PM
K5JMP's Avatar
quick question.... I tried the search function and came up empty...
I installed an aftermarket stereo in my '87IROC over the weekend...
now I notice no instrument lights. IIRC, I tied the yellow wire on the factory radio to the illumination wire on new box. I even checked it to be sure with a VOM and voltage varies with the rheostat.... but the other side of the factory connector had a brown wire on it that ties to nothing....
Curious if that's where I went wrong... any hints, clues or wiring charts???
TIA... mike
Old Jul 6, 2008 | 03:33 PM
Pontiacdaddy's Avatar
Car: 1987 Trans Am
Re: instrument lights out, aftermarket stereo
illumination wires on an aftermarket radio are usually orange.
there are two wires in the factory harness behind the radio that have to do with the lights.
one is grey and is for the dimmer one is brown and it is for illumination. i could have the colors fipped but i think this is correct.
the voltage on the grey wire will go up and down with the dashlight dimmer ****. the illumination wire will just show 12 volts when the parking lights are on and zero when they are off.
there shouldnt be any yellow wires involved with the lighting. yellow on the back of the aftermarket radio should be hooked to constant battery voltage which in the vehicle harness is orange.
here is a link to a wiring chart. it doesnt show the illumination wire in addition to the dimmer wire but i know it exists i did installs professionally for 4 1/2 years.
http://www.installdr.com/Harnesses/GM-Wiring.pdf
hope this helps
Old Jul 6, 2008 | 04:01 PM
K5JMP's Avatar
I had tied the dark brown wire to chassis on the radio.. my bad.. everything is fine now.
replaced the fender today.. be cleaning it up for paint soon
thanks for the reply
Ghettobird52
Jul 5, 2024 11:18 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
