Cassette TO CD Swap
Old Jul 10, 2008 | 08:44 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Cassette TO CD Swap
Are the factory connector(s) on the "car" side for a factory AM/FM Cassette unit identical to a factory AM/FM CD unit, for a 1991 Z28? In other words, can you take out the factory cassette and plug 'n' play a factory CD?
Seems like it would, but please let me know.
Thanks,
Bill
Old Jul 10, 2008 | 10:46 AM
camarobird92's Avatar
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
Re: Cassette TO CD Swap
Yes. The connectors are all the same. Even model to model. GM pretty much used the same connector for everything.
Old Jul 10, 2008 | 12:11 PM
Burnout91's Avatar
Engine: Modded L98
Thanks for the reply! I thought the connectors would be standardized, but wanted to check.
Bill
Old Jul 28, 2008 | 11:03 AM
Burnout91's Avatar
Engine: Modded L98
OK, I have obtained the factory AM/FM/CD. The three connectors present on my car are: white, 4-socket; blue, 4-socket; black, 6-socket. When I connect the plugs to the corresponding ports on the CD, and turn the key to acc, power is present as the clock displays and I can set the clock. However, the unit does not come "on" when I press the "POWER" button. Are any other connectors required on the CD, connectors that are not present on an AM/FM/Cassette equipped car? Thanks for any input!
Bill
Old Jul 28, 2008 | 11:25 AM
Are there any empty connections on the CD player after you plug them all in?
Old Jul 28, 2008 | 12:37 PM
Burnout91's Avatar
Engine: Modded L98
Yes, 2. On the cassette, there are 4 ports in a block, of which 3 are used. The CD has this same block of 4 ports, with the same key-ways for the connectors, plus an additional port (5 pins, i think) at the lower left hand corner of the unit, when viewed from the back. I thought this additional port might be for a power antenna???
Bill
P.S.: Refer to the second pic in the thread "Super rare OEM 91 Z28 AM/FM/CD player" thread.
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
