Radio died after putting new cd player in...
Car: 82 trans AM 97 Firebird
Engine: 305v8, 3.4v6
Ok, so i have change the old cd player to a new one, and the old one worked fine. Well i also got 100watts (2) plus 400 watts speakers on the car, It's like it blow a fuse or something? Do i need better wires or something so it won't blow a fuse?
Car: 89rs White
Engine: 305 TBI stock
Transmission: functional
Re: Radio died after putting new cd player in...
The watt rating on speakers is what they're made to handle, they don't produce power. The radio itself should have a fuse on it you can check to make you feel better, but that's probably not the problem.
Do any lights on the radio turn on? Did you double check your wiring?
yeah i have checked the wiring over and over, nothing comes on in the radio now. when i went to try to put the other one back on it didn't work again on there. all the wires are there and hooked up right.
might be the fuse which im hoping thats all it is.
eightsixseven
Dec 16, 2024 01:50 PM
ambainb
Apr 25, 2016 09:21 PM
db057
Aug 11, 2015 10:11 PM
