CD player help
Old Sep 2, 2008 | 02:38 PM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
CD player help
I have a 1985 trans am with a stock radio and i want to put a cd player in but i cant figure out the wires they do not match the cd players color code i got the cd player to start but i cant get the speakers to work maby some static as i change wires but no music?
Old Sep 2, 2008 | 03:52 PM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
Axle/Gears: 10 bolt 3.42 w/ Auburn LSD
Re: CD player help
The first few things that come to mind are: is the cd player new or use; if used then are you sure it works properly? Did the factory headunit work i/e play music? The speaker wiring is as follows:
(White Connector)
Left front (-) gray Right front (-) dark green
(+) tan (+) light green
(Blue Connector)
Left rear (-) yellow Right rear (-) light blue
(+) brown (+) dark blue
(Black Connector)
Ground - black
dimmer - brown
illumination - grey
power antenna (option) - pink
12V ignition input (switch) - yellow
12V battery (constant) - orange
If you happen to have the steering wheel controls, i am not sure about the wiring for this having never delt with it before. Does anyone else know/have the diagram for the steering wheel radio controls.
Old Sep 2, 2008 | 06:03 PM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
Re: CD player help
Thanks that would of helped a lot but i managed i will save that setup it works now.
Old Sep 2, 2008 | 10:03 PM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
Re: CD player help
hey no problem! good luck with the install.
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
kairles
Oct 26, 2015 09:13 PM
Linson
Oct 1, 2015 09:50 PM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
