Help with my new sub box
Old Dec 26, 2008 | 04:18 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
I just bought a box with 2 10" subs in it, and i want to know if i mounted it on my back seat (while its folded down) if it would sound bad or rattle? I have a 89' Iroc...... By the way it would be very helpful if somebody could tell me the easiest way to reach the 8th cylinder spark plug
Old Dec 26, 2008 | 04:44 PM
brandonj89's Avatar
Car: 92 camaro rs
Engine: 334
Axle/Gears: stock
Re: Help with my new sub box
hey there, i have a a 92 rs, and i have a box for 2 12" subs, i mounted it on the back seat also, but with the subs facing rear, it sounds amazing, very loud, clean bass. as long as you dont plan on having people back there youll be fine, but you really want to find some way of mounting it to the seat, i used 2 L brackets to sucure it to the seat so when you turn or brake the box doesnt fly forward or side ways. if you have any questions let me know. as far as the 8th cylinder spark plug, i found your better off going in from underneath the car. you have more space to work
Old Dec 26, 2008 | 05:11 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
Thanks, Hey i just bought my car , its a 305 tbi v8, im almost done with the tune up,but for some reason when im driving and im doing about 10-15 mph and i smash the gas my car hesitates for 2-3 seconds and then shoots off,my brother said it was probably a mixture of my timing being off and one of my plug wires being burnt all the way through
Old Dec 26, 2008 | 06:22 PM
brandonj89's Avatar
Car: 92 camaro rs
Engine: 334
Axle/Gears: stock
well if you fix your timeing and your plug wire and it still cuts out you might want to think about checking your injectors, i was having the same problem with my 92, and i check all the normal stuff (plugs, wires, etc) and it was still doing it, i put new injectors in, runs like a dream. make sure if you do get new injectors to get flow matched ones, their is alot of choices, so just shop around, i have a few sites to look at if you want them, just let me know and ill be happy to get them to you
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
