Single 12 box?
Old Jan 1, 2009 | 02:05 AM
bear88ss's Avatar
Car: 88MCSS/92Firebird
Engine: 421/355
Transmission: TH-350/4L60
Axle/Gears: 4.11/2.73
Single 12 box?
Looking for a single 12" box that is right on the button of 1.5 cubic feet... does anyone make one or do I have to build it?
Old Jan 1, 2009 | 02:31 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Single 12 box?
Had to have one built for mine. About the same air space as you're looking at and made from MDF and fiberglass. The plans for the enclosure are loosely based on the plans in the stickies above, but fiberglass is used for the bottom half. You can find pics here....
https://www.thirdgen.org/forums/car-...amp-build.html
Old Jan 1, 2009 | 11:40 AM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: Single 12 box?
No one sells a single box for either 10 or 12 in subs. Alot sell them from dual 10s or 12s thou. Either you could build one on your own, have a shop build a custom one to match your car exactly, or find a used dual tweleve and rebuild the box(remove divider between too sections, and replace top piece with only one hole in the center).
Old Jan 1, 2009 | 08:46 PM
bear88ss's Avatar
Engine: 421/355
Re: Single 12 box?
Ok thanks.
Old Jan 2, 2009 | 06:49 AM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
Re: Single 12 box?
$750 L98
Feb 1, 2025 02:25 PM
Night rider327
Oct 9, 2015 09:25 AM
loud91rs
Oct 5, 2015 10:05 PM
tattmann
Sep 27, 2015 05:20 PM
Dragonsys
Sep 25, 2015 03:51 PM
