Kick Panel vs Door Pod
Old Jan 19, 2009 | 10:35 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Hey all.. I have a decent stereo in my camaro and need some advice. I'm running 2 Rockford Fosgate p2s 2 alpine 6x9s and 2 pioneer 4x6s.. the pioneers were in there when i bought the car and i havent messed with them other than hooking those and the 6x9s up to a 4 channel amp.
My question is: Are kickpanels or door pods better. I ran across a brand new set of Rockford Power 6 1/2s cheap and want to use them. Problem is i have manual windows and manual transmisson.. So im not sure if id be able to use either kick panels or door pods.. any info would be appreciated..
Thanks guys
Old Jan 21, 2009 | 01:24 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Kick Panel vs Door Pod
I honestly would go with a door pod, that would make the speakers closer to you and more out of the way...
Old Jan 21, 2009 | 08:55 AM
Axle/Gears: stock
would that interfere with the window crank at all? Generally thats would be were i would put the speaker.. would it make any difference if its centered on the bottom or maybe above the window crank if possible?
Old Jan 21, 2009 | 01:04 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Kicks produce a more correct soundstage because the speakers are more equidistant from your ears. A DSP can help you compensate for the difference but most people aren't that serious about their tunes...I'm an audio geek. LOL
Old Jan 22, 2009 | 01:57 AM
HCR13's Avatar
Car: 1987 Trans Am
well, most people wouldn't cut a hole in the door, but rather build a small speaker pod bolted to the door panel. Do a search, there are tons of them on here...I'm planning to do my own doorpods this weekend...
Old Nov 26, 2010 | 07:01 AM
J_Makk z28's Avatar
Car: 1986 IROC-Z 5.0
Engine: 305 TUNE PORT
Axle/Gears: 3.73?
BTW cutting a hole in the door panel isn't a very good idea. speakers wont fit very well and you pose a risk of damaging the speakers. go with a home made pod or many after market that custom make them
just my 2 cents
Old Nov 26, 2010 | 12:46 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I like door pods, but kick panels are an option, yu will get better sound distribution out of a component setup on the doors, you need to build out with them though because they look like crap flushed and they can cause clearance issues, if you build a pod you can even angle them to fire up and any direction you want
Old Nov 29, 2010 | 12:03 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've done both. With manual windows, 6.5s in the doors are a tight squeeze. With power windows, you've got to build the door out a mile.
As for sound quality, both have their pros and cons, but I find that it's a lot easier to correct the frequency response issues associated with kick panel placement than it is to try and get a good soundstage from door locations.
Old Dec 4, 2010 | 03:14 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
My door pods are fairly slim. They stick out less than the width of the arm rests. I have power windows and have holes cut into the door to fit up to a 3" (max) deep midbass speaker.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
