Need Some Help With An Older Alpine (7816) Diagram....
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Was hoping someone might know the correct locations for the following harness (see below). I'll hopefully be upgrading in the coming months, but for now, I need a freaking radio lol. The wires are as follows, and any help would be greatly appreciated....
Alpine 7816
Black
Yellow
Red
Pink w/White Stripe
Blue
Blue w/White Stripe
Grey
Grey w/Black Stripe
White
White w/Black Stripe
Green
Green w/Black Stripe
Purple
Purple w/Black Stripe
Thanks again...!!!!
Alpine 7816
Black
Yellow
Red
Pink w/White Stripe
Blue
Blue w/White Stripe
Grey
Grey w/Black Stripe
White
Green
Purple
Thanks again...!!!!
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: Need Some Help With An Older Alpine (7816) Diagram....
red is power black is ground yellow might be acc then the seaker wires i lost my diagram and tested it one by one.
^ so your saying that Red is Constant, Yellow is Ignition (Key On), Black is Ground....?
From the picture, it appears that the speaker wiring would be the two; Grey, White, Purple and Green wires. Pretty sure that Blue is the antenna, although I forget why there are two of them, and the Pink one has me scratching my head lol. Thanks....
-Rob
-Rob
Grays and purples are the rights. Whites and greens are lefts. Whites and grays front. Purples and greens are rear. Striped wires are negative. Pink is probably a cel phone mute back when hands free kits were popular.
Alpine 7816
Black Ground lead
Yellow Battery lead
Red Switched Power ignit on lead
Pink w/White Stripe Audio interrupt in lead
Blue Power Antenna Lead
Blue w/White Stripe Remote Turn on Lead
Grey Front SP (R) +
Grey w/Black Stripe Front SP (R) -
White Front SP (L) +
White w/Black Stripe Front SP (L) -
Green Rear SP (L) +
Green w/Black Stripe Rear SP (R) -
Purple- Violet Rear SP (R) +
Purple- Violet w/Black Stripe Rear SP (L) -
Thanks again...!!!!
Alpine 7816
Black Ground lead
Yellow Battery lead
Grey Front SP (R) +
Green Rear SP (L) +
Thanks again...!!!!
JXS
