What type of amp
Old Feb 3, 2009 | 03:45 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
What type of amp
Currently, I have Infinity Kappa 692.5i rear speakers and 462.5cfp front speakers. I am not looking for a super system, but rather something that sound decent. I plan on using a quality head unit as well.
The fronts are rated at 60 watts rms and the rears are 110 watts rms. Both are 4ohms impedance.
Old Feb 5, 2009 | 01:27 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
Re: What type of amp
check out an eclipse or alpine 4 channel. something with about 75-85x4
you can always turn down if its too much for your fronts. i would just def say, make sure there is a high and low pass x-over on each channel. you'll want to run the fronts on low pass about 400hz, and run a low pass on the rears at about 70hz. they cant handle that deep sub bass, but you will def get a round sound.
Old Feb 5, 2009 | 01:35 AM
hellsatan's Avatar
Car: 89 IROC
just get a 350rms 4 channel amp. you notice the difference right away. once tuned it sounds way louder. I use to listen to music on my deck at like 20-25 (fairly loud). Now with my amp I listen to it at like 15. Makes a huge difference. 20-25 now is ear bleeding, can barely hear myself talk.
Old Feb 19, 2009 | 12:07 AM
Car: 91 Camaro RS
Would something like a Infinity Reference 475a work well?
Old Feb 19, 2009 | 04:20 PM
Car: 91 Camaro RS
Or JVC KSAX4504?
Or PowerBass ASA-600.4?
Old Mar 6, 2009 | 10:16 PM
Car: 91 Camaro RS
I ended up getting the PowerBass ASA-600.4 and mounted it in the spare tire area. Post to come in the future.
Old Mar 22, 2009 | 08:38 AM
Car: 91 Camaro RS
Still have to fine tune the settings, but now will get loud without distorting.
Old Mar 22, 2009 | 11:29 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
hours of tuning distortion is alot of fun!
Old Mar 24, 2009 | 05:45 PM
Car: 91 Camaro RS
I realize that the tuning is done by a very unprecise device (ear), but can you provide any tips on setup?
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
raymondandretti
Sep 27, 2015 06:43 PM
