Interference - RCA cables, or power outlet?
Old Feb 13, 2009 | 01:40 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
So I recently installed Sirius radio plug and play kits in two cars, both done the same way, and both have the same problem. Both are aftermarket head units with RCA inputs. The Sirius is powered via a new accessory outlet in each car (still wanted to retain use of factory outlets). There is interference that corresponds to engine RPM. I've been reading up on the issue and have determined it's either in the RCA connections or the power/ground at the outlets. I tried a ground loop isolator I had laying around on the RCA cables and it simply drained much of the sound. I plan to throw one in my Trans Am soon, and would like to make sure I have it down before I do. How should I test to see which is my problem and how should I fix it? Thanks in advance.
Old Feb 13, 2009 | 03:49 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Interference - RCA cables, or power outlet?
you need to ground the sirius's -wire to the same spot as the head unit. if you have subs, i would ground the head unit and sirius reciever at the same spot as the amp ground cable to chassis point. the noise is alternator feedback, i doubt its in the rca's. sounds like a power circuit ground loop.
Old Feb 13, 2009 | 04:35 PM
87GTAj's Avatar
Engine: 5.7L TPI
Ok, so the ground wire for the Sirius (i.e. the accessory outlet) should be at the same spot as the head unit, is that correct? I figured it was alternator feedback as well, just wasn't sure if it was somehow affecting the RCA being that they aren't heavily shielded.
Old Feb 13, 2009 | 04:42 PM
i would personally cut the cigar lighter adapter off the sirius harness and just wire it to the radio, but if it has a built in convertor in the adapetr it will be a little different.
but basically, wire the sirius to turn on with the radio, and it should eleminate the noise.
oh and do you have subs andd amp?
Old Feb 13, 2009 | 05:09 PM
87GTAj's Avatar
Engine: 5.7L TPI
I just went outside and hooked up the acc. outlet ground to the head unit's ground and the noise is practically non-existent and does not change with regards to RPM. I was originally going to hard wire the Sirius, but it has a built in 12V -> 5V circuit, so I just wired in a new outlet ($3) to tuck it away. The car I just fixed has no subs and no amp. The other car has a factory amp, and the Trans Am will be getting an amp to power two additional speakers. Basically, would you suggest grounding ALL audio equipment to the same point?
Old Feb 13, 2009 | 05:19 PM
factory amp should be fine, but generaly speaking common ground is the best way. glad its solved.
Old Feb 13, 2009 | 05:57 PM
87GTAj's Avatar
Engine: 5.7L TPI
Thanks for the help.
Old Feb 23, 2009 | 12:49 PM
87GTAj's Avatar
Engine: 5.7L TPI
Alright, in one of the cars (the one with the factory amp) the interference came back - it's not nearly as bad as it initially was, but it is very noticeable. Any ideas?
Old Feb 23, 2009 | 02:05 PM
donno, try grounding the radio/sat receiver at the factory amps ground location.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Caspar
Jun 19, 2016 11:19 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
