"My custom stereo".....I've seen tons of them
Old Mar 2, 2009 | 06:12 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
We know these threads, someone posts a link or picture to a "custom" stereo and it's one of those pre-fab'ed boxes with a amp screwed down in the middle of it. Old dingy carpet is still in the car and the box carpet is standard grade speckled trunk carpet.
What about you guys that take a lot of pride in your car and go the extra mile to make sure all the materials match (ie; carpet on the box matches interior carpet exactly) or even a custom vinyl covered speaker enclosure / amp rack that's hidden by a custom carpet??
How about custom kickpanels or door panels that have build-outs that match the interior colors almost perfectly? Not just a set of pre-colored q-forms and call it a day?
I mean I can do a search all day long on custom stereos and the stereo's may sound good but making sure it looks like it belongs in that particular car is more of an afterthought.
I hope I didn't ruffle any feathers, but I would like to see more cars that have stereos that look like they "belong" in the car and it looks like it could be something GM would have done, I hope that makes sense?
Old Mar 2, 2009 | 09:24 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: "My custom stereo".....I've seen tons of them
Aside from the aforementioned Q-forms in the kick panels, which I would like to something about, I like the way mine blends with the rest of the interior. Touch screen display on the head unit matches almost perfect with the digital gauges. In the rear is an enclosure for a singl2 12" Memphis MOJO and the amplifier for the entire system, a 5 channel Memphis Belle.
My head unit and digital dash with gauges for stereo amp voltage/current/temp under the center vents.
The heart of the system without its cover...
And with its cover (carpet covered perforated steel with a square tube steel frame)
Old Mar 2, 2009 | 09:44 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Are those the Nordskog gauges?
Old Mar 2, 2009 | 09:47 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Al Hasse, who makes those gauges? Also, on a scale of 1-10 how hard was the install (granted cutting into VSS ect.)?
Old Mar 2, 2009 | 10:07 PM
Al Hasse's Avatar
Gauges are Dakota Digital. Install was pretty straight forward, a good schematic helps lots. Just find the correct wire on the harness to the original gauges and tap into that, then run it to the Dakota Digital microprocessor unit. Makes for alot of wires under the dash, especially if you already have an alarm system installed.
Old Mar 3, 2009 | 04:10 AM
Car: 1971 Camaro
Yeah yours was one of the examples I was talking about, I almost posted a link to your pictures in this thread. It's an example of a well thought out and installed stereo system.
Old Mar 3, 2009 | 08:55 AM
87SnowFlake's Avatar
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
Al Hasse do you think you can post a picture of the t-tops strapped down in the back? I would just like to get an idea for the enclosure i want to build. Thanks
Old Mar 3, 2009 | 11:06 AM
Al Hasse's Avatar
It doesn't look any different than having the stock hinged cover over the well
Old Apr 8, 2009 | 12:46 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
im going chime in on this one because I like that and want to do something like that.
Old Apr 8, 2009 | 01:07 PM
87350IROC's Avatar
Car: 87' IROC
Where did you get the carpet. I trying to find some in the same color but am not successful. Also where did you get the carpet for your sub box cover.
Old Apr 8, 2009 | 01:45 PM
Car: 1971 Camaro
I ended up doing something like that, I may change the cover around a bit by making a custom mat to fit the whole area....that way the board isn't so obvious.
You can get carpet either with ACC or maybe a close match here.
http://www.yourautotrim.com/80wideozite.html
Old Apr 8, 2009 | 03:30 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Mine is pretty simple "My custom stereo".....I've seen tons of them-dsc00079.jpg
Old Apr 8, 2009 | 03:50 PM
87350IROC's Avatar
Car: 87' IROC
88transamfreak
Yeah I ordered their sample sheet. Will check it out.
I recall from a previous thread, Al's top cover was using acoustic carpet. I'm wondering where he got that.
Old Apr 8, 2009 | 07:09 PM
Al Hasse's Avatar
I had mine installed, the carpet is the same stuff that the shop uses to cover custom boxes that they build, they get it in bulk. It's not much different than what 88TransAmFreak posted except maybe a little more "stretchy" to conform to some odd shapes.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
