Drilling through Fire Wall
Old Mar 15, 2009 | 04:50 PM
musclecars90's Avatar
Car: 1986 Iroc Camaro
Engine: 305 5.0L
Transmission: 700 R4
Where will be the best place to drill, so I can run my amp wires to the battery.
Old Mar 15, 2009 | 05:15 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
Re: Drilling through Fire Wall
Right around the brake booster is the easiest place to reach. Just make sure to reference something from the inside to the outside before drilling.
Old Mar 15, 2009 | 08:56 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
^ +1 and start you hole small incase it is gonna hit something.
Old Mar 17, 2009 | 12:41 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
i drilled a hole for my amp right above were the hood latch cable comes thru. its really easy to access from the inside to.
Old Apr 1, 2009 | 07:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Being that your battery is on the passenger side (since you have a Camaro), I would check out the area behind the kick panel on that side. I ran mine right next to the antenna grommit, but I don't know if you'll have the same amount of clearance if your antenna is power.
Old Apr 1, 2009 | 10:33 AM
88_TeenTrans's Avatar
Car: 1988 Fire Bird (T-Roof)
Engine: 5.0L 305 TPI
My first question is WHY?!?!! There are lots of spots you can run your cables without drilling holes. Look under the dash pull some of that carpet back and look behind the brake pedal. there wil lbe a gromet right there. take a screw driver POP it out and run ur cables from the battery across under the shrouding covering the rad up to the corner then run it straight up to the hole make sure u seal that hole with something as well. That rubber gromet is to protect the cables and wires from the edges of that hole. HOPE THIS HELPS
Old Apr 3, 2009 | 02:21 PM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
is this gromet on all camaros???
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
