Damn Car stereo
Old Apr 19, 2009 | 08:09 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
Damn Car stereo
i just bought a headunit off o friend and wiried it up in my car with the factory speakers but it still wont play not even static does anyone know the factory color codes for the stereo wiring in a 1991 Camaro
Old Apr 19, 2009 | 09:32 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: Damn Car stereo
You need to elaborate a lil more. If you getting static from the speakers and it wont "play" then im assuming it turns on but u just have no sound. Is this from the radio, or cd/ipod? If you are getting static from speakers when ur in tuner mode then u obviously have ground and power and somewhere one of the speakers is at least hooked up(in the right spot or not, it doesnt matter). So i would guess you didnt hook up your attena right, which will cause static. Im only going off assumtions as you told us nothing but your gettin static and it wont play.
Old Apr 20, 2009 | 11:08 AM
Camman9167's Avatar
Car: 1991 Camaro RS
Axle/Gears: Factory
Re: Damn Car stereo
I mean there is no static at all, and when you play a cd no sound comes out even though the headunit is on and says its playing the cd. The headunit turns on and off with the car and holds time but thats all it does
Old Apr 20, 2009 | 03:58 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
Re: Damn Car stereo
ahhh...alright that means the speakers arnt hooked up at all. Could be you messed up the wiring or maybe speakers are unhooked from the connections(or bad connection). I would double check all your speaker wires
Old Apr 20, 2009 | 04:54 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Axle/Gears: Factory
Re: Damn Car stereo
ok im thinking about just rippin them outta the car and putting all new ones in i figured the connection was bad thanks
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
