Stereo sounds really low
Old Apr 24, 2009 | 05:11 PM
Racer86y's Avatar
Axle/Gears: stock?
I hooked up my wiring and put factory Bose stereo in my car and you have to strain to hear it.The wire clip was cut off so i got another one and wired it color to color exactly.Where did i go wrong?
Old Apr 24, 2009 | 05:16 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: Stereo sounds really low
did you get the bose amps to go with it? That might be the problem.
Old Apr 24, 2009 | 05:22 PM
Racer86y's Avatar
Axle/Gears: stock?
What bose amps?I figured if it plugged in then it should be ready to go.Where are amps located?
Old Apr 24, 2009 | 05:23 PM
Car: 1971 Camaro
Not sure, maybe under the dash on the passenger side. It's my understanding that the bose systems used a dedicated amplifier for the speakers.
If your trying to convert a non-bose car to a bose system that may be the problem.
Old Apr 24, 2009 | 05:28 PM
Racer86y's Avatar
Axle/Gears: stock?
I do not know if its a Bose car or not.There was nothing in it when i got it.90 Camaro RS is about all i know so far.
Old Apr 24, 2009 | 08:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Bose head units are preamp output only-you will have
to hook an amp up to it-easy job,works great(check
the "bose head unit"post for more details) With a
stock bose system,each speaker housing has a special
low voltage amp for use with the special 1/2 ohm
bose speakers.
Old Apr 24, 2009 | 11:02 PM
Racer86y's Avatar
Axle/Gears: stock?
What about a 94 Monsoon,could i just plug it in or does it have to have amp also?
Cornholio7979
Sep 20, 2018 02:31 AM
87iroctheo
Dec 4, 2016 11:47 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
tc7761
Aug 30, 2015 09:45 AM
