Awesome looking DVD player...
Old Mar 24, 2009 | 07:36 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Been looking to upgrade my 92's sound system, and found this sick player. Only problem is Crutchfield says it doesn't fit Maybe it can be modified to fit, i'm not sure, but it definitely would be cool to try.
Link
Old Mar 24, 2009 | 08:54 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: Awesome looking DVD player...
unless I'm missing something it looks like a din sized receiver...and technically should fit with any aftermarket mounting kit.
Old Mar 25, 2009 | 12:06 AM
ThePain's Avatar
Car: 1992 RS
That's exactly what I was thinking. Hell the older model of this looks nearly the same and everything.
New one:
Old one:
And another JVC
Old Mar 25, 2009 | 08:11 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Probably depth is where the issue is. I got a pioneer unit when they first started using the full OEL displays. It was too deep for the radio pod on my firebird. But, I cut into the inner structure of the pod so that it would slid back in there. Also...I minimized the wiring by not using a plug and play adapter and just soldered it all the old school way.
Also with that radio, I used an install kit that stuck out. That helped with about an inch or so more space. The radio i have now fits in a recessed kit, so its flush with the front fo the pod. You'll have to check the depth measurement against a head unit that fits without mods to see how bad it is.
If its single Din...it'll fit. But crutchfield isnt going to say it fits if you have to cut into your stock parts.
J.
Old Mar 26, 2009 | 12:46 AM
ThePain's Avatar
Car: 1992 RS
That inner structure, the rear bracket or whatevers back there taking up space. Is it possible to unscrew it, or maybe bend it incase I ever needed it again?
Old Mar 26, 2009 | 07:41 AM
cdoyle's Avatar
That bracket comes right out, I believe there are 4 bolts hold it in.
Old Mar 26, 2009 | 08:06 AM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Originally Posted by ghettocruiser
...If its single Din...it'll fit. But crutchfield isnt going to say it fits if you have to cut into your stock parts.
J.
This is very true. If it will fit with no modifications they will tell u. It will say it wont fit if it needs modifications. Im a huge supporter of crutchfield. I would check the specs on the site it should tell u the depth of it. Just measure before u buy it. If still not sure give them a call. They have amazing customer support. Before i became a known-by-first-name guy at the local car audio shop i used crutchfield for everything. It should fit though.
Old Mar 26, 2009 | 12:05 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
My deck sticks out about an inch so im sure they mean depth.
Old Mar 26, 2009 | 02:30 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
yeah that should fit with an adapter. just cut the stock bracket for more room
Old Apr 25, 2009 | 01:42 AM
ThePain's Avatar
Car: 1992 RS
Sorry to bump up an old thread, but figured it was better than making a new one.
Crutchfield just updated their page on this dvd player, they're saying now that it does indeed fit, albeit modified.
Installation Details for your 1992 Camaro
» To install this product, you�ll have to modify your vehicle. » Extension kit -- when installed, the radio will protrude from the dash by 1/2". » Unbolt or cut out the factory stereo's rear support bracket to make room for your new receiver.
Now I'm just wondering then, and maybe someone who's bought a player that's had the same installation details.
Will the unit still stick out a 1/2" AFTER removing the rear support bracket? Or would it do that if I didn't remove the bracket?
Ideally I'd want a flush fit... I'm waiting for an email back from JVC on the exact size of this thing
Old Apr 25, 2009 | 04:33 PM
ThePain's Avatar
Car: 1992 RS
Alright... Excellent. Some nice CS from JVC
The dvd's dimensions:
(WxHxD) 7-3/16", 2-1/16", 6-5/16".
The panel size is 7-7/16", 2-5/16", and 1/2".
So how big is the area in there for our cars? Without the bracket?
Or maybe what's the bigger player you've got inside there?
Edit: Okay i found it on Crutchfield :5-5/8"
I assume that's with the bracket in... So it shouldn't be much of a problem
Abubaca
Nov 5, 2016 12:22 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ndndndnd
Sep 28, 2015 08:00 AM
!CamaroDave
Convertibles
Sep 17, 2015 12:53 AM
