Performance Sound Subwoofer Replacement
Old Apr 27, 2009 | 06:04 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I'm looking into upgrading the sub woofer in the Firebird Performance Sound system I've pieced together, not using the stock 50W amplifier, using a different GM amplifier, one per sub woofer, probably puts out about 50W each amp, so I'm not concerned about the amplifier aspect. Right now the box has these:
Audiobahn AS40Q: http://www.onlinecarstereo.com/CarAu...roductID=14046
not a bad sounding speaker, but it's clear that it wasn't made for bass, and obviously it's not a sub woofer by anyone's standards, maybe a mid. Plus it's a 4" speaker and has a tiny gap on every flat edge. Now i know that everyone is going to say go aftermarket, but I do not want aftermarket. I like that they replace the stock 6X9s and I have a lot of room in my trunk, I can also use other amps I have to power the 4X9s above them and get another set of amps for each under dash speaker. I'll figure out the rest of the system as i go along with a little guessing and testing. Right now i just want a sub woofer to replace the ones that are in there now. Which one looks to be the best from the following, and I'm open to any 5" - 5.25" sub woofer that someone can find.
Here are two that i've found:
#1 http://www.parts-express.com/pe/psho...31&ctab=1#Tabs
# 2 http://www.overstock.com/Electronics...0/product.html
I like number two because of the 100W RMS, but number two has a lower frequency range and a similar SPL. Not to mention the rubber on number one actually looks like rubber and cone for a sub woofer with good extension. Let me know what you think I should go with!
Jon
Old Apr 27, 2009 | 06:22 PM
84redta's Avatar
Re: Performance Sound Subwoofer Replacement
Also got the details on subwoofer number one in the attached link.
File Type: pdf
Old Apr 28, 2009 | 07:22 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
When I was starting to read your post, the first brand to come to mind was Tang Band, but it appears you beat me to it. Just make sure you're running too low an impedance for the amps you plan on running. While you may not get much out of such a small "sub", I don't think the TB's will disappoint, especially for the money.
Old Apr 28, 2009 | 10:28 AM
84redta's Avatar
I know, I used to use nothing less than 12s, but like I said, I like the idea of full use of the trunk and lock box in the back, and I'm looking to add a little flavor, maybe vibrate the mirrors a little, sound really good in the car, don't care bout what it sounds like from ten feet away or being heard down the block. Just a little extra oomph, ya know? I saw a company, Focal I beleive with some sick 5" subs for nearly $200 and $500. Yeah no thanks, LOL. Not to mention for the money I figured they wouldn't be terrible, and definally not a fan of Pyramid so.
Each amp is able to run at 2 ohms, and I'm planning on running 4 ohm speakers, so they should be alright. Thanks for the insight!
Jon
Old Apr 29, 2009 | 07:14 AM
84redta's Avatar
Anyone else have input on these subwoofers, possibly anyone with experience with either one, and what setup you put them in. Opinions pertaining to the use of a 5" sub, whether one listed or not, will be greatly appreciated! Thanks!
Jon
Old Apr 30, 2009 | 03:10 PM
84redta's Avatar
Noone??
Old Apr 30, 2009 | 05:20 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
I have a set of those sail panel speakers, but they still have the stock speakers. I was trying to figure out what to replace them with. The Fiero Store has similar speakers that will drop right in place of teh sub portion. What they sound like...not sure. One of these days I'll get around to getting these into the car.
Old Apr 30, 2009 | 06:12 PM
84redta's Avatar
Yea, a post from the past win you in it mentioned that. I went to the link that was in that page, by they didn't have the sub listed under speakers. Not to mention, aftermarket will always be better. LOL.
Just an FYI to whomever is looking to do this. 5.25s are too large, you do need 5s. I tryed to see if trimming to fit was available, and it isn't without sacrificing integrity and design of the panel. To this day, I have been unable to find a small yet suitable amp to power these speakers and have resorted at the moment to 6X9s to pass the time. When/If i ever go down this road again, i will report back my findings.
Old May 3, 2009 | 04:26 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I like the Tang over the other brand.
How about putting an 8" sub where the rear 6x9 goes? Then run a 5 1/4 co ax in the dash?
Just an idea.
Old Jul 1, 2009 | 09:05 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Any update on this? I've been doing the same search with not much luck
-jason
Old Sep 29, 2009 | 03:33 PM
TinmanOshika's Avatar
Car: 1987 Formula, 2007 Avalanche
Been working on this myself for a couple of years for my 87 Formula... Just cant find a good aftermarket replacement for reasonable $$. Tried a Pioneer 2way, and a Radio Shack sub. The Radio Shack model did not fit the box and the Pioneer just doesnt sound near as good as the stock part. And searching for the 'part' is like looking for a needle in a haystack, for an older car. Anyone know of a replacement OEM part that is used in another GM car, besides the Fiero?
Old Sep 29, 2009 | 04:05 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
how about the 5.25's on that page
http://www.cdtaudio.com/custom_components_08.htm
I dunno if you've heard of CDT audio, theyre really good.
Old Sep 29, 2009 | 05:11 PM
Car: 89 IROC
Try contacting Kee Audio. He does 4th gen replacement systems and should be able to help you.
http://www.keeaudio.com/contact.html
CDT is Ok for the money but there are better choices IMO
Old Sep 29, 2009 | 07:43 PM
Axle/Gears: Stock
Better than pyramid thats for sure =]
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
