subs in 85 camaro
Old Sep 22, 2009 | 04:21 PM
vampyrico's Avatar
Car: 1985 Chevrolet Camaro
Engine: V8 lb9 i believe..
Axle/Gears: 10 bolt posi
subs in 85 camaro
im interested in getting 2 of these subs for my camaro.
http://www.edesignaudio.com/product_...roducts_id=818
i want an amplifier from the same company to go along with it.
http://www.edesignaudio.com/index.php?cPath=1_22
which one of the three will work for the two subs?
thank you. i like the direct fit box from q-logic for my car.
Old Sep 27, 2009 | 01:02 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: subs in 85 camaro
never heard of that brand of amps or subs.....
Old Sep 27, 2009 | 09:42 AM
vampyrico's Avatar
thanks for replying atleast. www.edesigns.com is their site. the equipment looks very solid. and it sounds good on you tube. i just dont want to wire it up with the wrong amp you know.
Old Sep 27, 2009 | 10:30 AM
5215's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 2.8 - Bored/Stroked, Pacesetters
Transmission: 5 spd Manual
Axle/Gears: Stock
WOW!! Elemental Designs makes excellent subs and amps. I've heard that the subs are very sensitive regarding the air space (Cubic foot) of the boxes you run them in. In my opinion, an excellent choice of equipment.
Old Sep 27, 2009 | 10:37 AM
vampyrico's Avatar
the box will be a direct fit box into my rear well. it will have the recomended 65cf per side. ive been thinking of relocating my battery to the glove box area of the back of my car. if i do that it would make both the power and ground cables significantly shorter for the sound system (not doing it specifically for the system). i think that amp is rated to handle the subs. but i wanted to be sure. heres a link to the head unit ill be using. http://www.crutchfield.com/p_099CD72...clipse&tp=5684
i have an eclipse cd3100 in my civic now. it sounds amazing. ive had that head unit for about 4 years now.
Old Sep 27, 2009 | 10:00 PM
5215's Avatar
Axle/Gears: Stock
Hey man, if you want a GREAT site for audio installs check this out:
http://www.diymobileaudio.com
There is a HUGE amount of installs featuring elemental Designs products. You have to create a profile to access the photos but it's free for the base site access. Just some food for thought!
Old Sep 29, 2009 | 05:28 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Ed make good subs but their cust service absolutely sucks. The Ed amps are prone to blowing. Many complaints on car audio forums.
Cadence make good inexpensive amps. As for subs, have a look at Stereo Integrity. They run about $250. Also, Image Dynamics, JL Audio (JL3), Fi, SSA Icon, the list goes on.
If you tell me how much sq.ft. you have for each sub we can go from there. I could see on the qlogic website.
You need to figure out a budget for the amps and subs as well as what you want (spl, loud-n-proud, sound quality).
Old Sep 29, 2009 | 10:19 PM
slow305rs's Avatar
Try..............
-FI Q
-SSA Icon
-RE SX
-SI Magv4
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
