Where to mount fuse / wires in 92' Firebird?
Car: 1990
Axle/Gears: stock
Re: Where to mount fuse / wires in 92' Firebird?
bad idea. dont run power directly from the battery.
you have a fuse box under the drivers side by your feet. there are empty slots there - use them and put a fuse it.
why reinvent the wheel?
I have an 80AMP inline-fuse holder that came with it. I know not hardly anything about electricity so i'd rather just follow the directions lol.
Car: 1987 Trans Am
Engine: LQ9/L92
Always fuse within 18" of the battery. I always had to drill my own holes, but there may be a spot below the brake booster on the driver's side (if thats the side your battery is on). As for running the cables, there is plenty of space underneath the door sills to hide it.
Also, if you are adding amps to the car, take the time and upgrade the "big 3". Your electrical system will thank you.
I don't suggest tapping a 4 gauge power wire into the stock fuse box.
Just pull the carpet back and drill a hole in the area above and to the left of the brake pedal and below the booster. Use the grommet that came with the kit.
Won't work like that, he'll either keep blowing fuses or melt something in the process.
Ghettobird52
Jul 5, 2024 11:18 PM
