need help with bose not working
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
I have an 87 iroc with delco bose. The factory radio was missing so I put a stock radio from a 87 s10 in it. Heres the question, Radio turns on and I know it works cause I listened to it in the s10, But no sound comes out of any of the bose speakers. Will the bose system not work with a non bose radio or is my bose speakers or amp fried or is there any other parts that make it work, like a control box or something hidden in the dash? I want to keep it as factory as possible any knowlege about this would be greatly appreciated.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: need help with bose not working
Bose systems have a wire(pink i believe)that needs
hooked up to turn on the amps(one at each speaker)
Also radios used with bose system are preamp output
only,so if used with the amplified radio from the s-10
the volume will max out as soon as the volume is
barely turned up.
barely turned up.
Car: 87 iroc
I hooked the pink wire up and and it was too loud just like you said. So i put in a pioneer cd player and wire in a set of rca adapter to the stock wiring harness and hooked the pink wire to the amp remote wire and everything works normal. Thanks for the help
Terrell351
Jun 13, 2021 01:13 PM
db057
Aug 11, 2015 10:11 PM
