Wanna Keep stock radio, but also want subs!
Old Sep 11, 2009 | 11:22 PM
bigpaulz28's Avatar
Car: 1986 Iroc-Z
Engine: LB9 305 tpi
Transmission: 700-R4
Does anybody know, how to put RCA inputs on a stock Delco radio, or a place that could do it, or a way to connect it to an amp?
Old Sep 11, 2009 | 11:59 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Re: Wanna Keep stock radio, but also want subs!
Have you tried googling the info? Try that first!......I did, lotz of info/hits!
Old Sep 12, 2009 | 02:00 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
u need i think they are called line drivers. if you are just doinmg subs a 15 dollar one will do, but if ur going mutiple channels including mids and higs itll be about 150
Old Sep 12, 2009 | 09:50 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I'm planning the same type of set up, except I want to install an amp to power the whole system using the stock deck. You need a line level converter to change the speaker level outputs to RCA preamp inputs for an amplifier. Most audio stores will have one type or another of these.
Try one of these and you can add an amp for all four channels...
http://www.crutchfield.com/p_142SLC4...nverters&ssi=0
Old Sep 15, 2009 | 11:37 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
just take it somewhere with your sub, box, amp and cash. let the pros do it =P shouldent be to much..
Old Sep 15, 2009 | 02:29 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
nuggie
Aug 25, 2015 01:27 PM
