Amp cuts on and off and sub has to be grounded to itsef???
Old Oct 4, 2009 | 09:47 AM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
ok guys i have checked all of the cables and everthing is fine for the amp. It is a 340 watt jensen and has some nice LEDs on the top that light up but on the side the green power light nor the power protect light come on. But when i go over a major bump it comes on . also i have a 10in audiobhan i know iknow but it only works when i have the negitive cable from the sub( it has 4+ and 4-) touching itself, sobasically when its grounded to itself. any help woulld be great.
Old Oct 5, 2009 | 06:27 AM
1986350's Avatar
Engine: 350 4bbl
Re: Amp cuts on and off and sub has to be grounded to itsef???
Bump
Old Oct 5, 2009 | 11:46 AM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Can you explain this a little more clearly? You say it only works if you take the negative speaker cable and touch both sides to the speaker? I would verify that the Amp + is direct to the battery, the Amp negative cable is grounded properly within 18 inches of the amp, and the remote wire is connected properly. Then if you are running the amp bridged, make double sure you have the speaker wires connected to the proper terminals.
Old Oct 5, 2009 | 12:20 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
If you are correct in saying that all the wires are correct then it sounds like internally the amp may be bad. If everything wiring wise is perfect and the amp still doesnt work inless you hit a bump the board might have a loose connection or something to that sort. And im not sure what your saying about only negative on the sub. Like said above be a lil more clear on that one.
...Its possible you have the sub wired wrong and are giving the amp a wrong load. You did say it wasnt going into protect mode tho. Some amps wont go into protect if you mess up wiring and some will.
Old Oct 5, 2009 | 01:53 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
might the cable going to the sub be clipped? like some of the wire is exposed at some part and is touching metal... i had that problem in mine, there was a small tear in the rubber of my speaker wire and it was touching the door panel. it would short out the amp and would go into protection mode, it sounds like u have a similar issue
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
FormulasOnly
Sep 6, 2015 10:42 AM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
