Capacitors In Series With My Speakers
Old Oct 25, 2009 | 12:21 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi guys,
I just took the 6x9 infinity speakers out of my firebird (out of action for a while) to put in my camaro and noticed some electrolytic capacitors wired in series (on the positive end) on each speaker. The PO had subs and an amp of some kind, found a poorly routed power wire when I took the interior out. So what would the caps be for and should I remove them? The speakers sounded pretty good in the bird with a factory radio (what I'm using in the maro).
Alex
Old Oct 25, 2009 | 12:34 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Capacitors In Series With My Speakers
Basically a bass blocker. Keeps the low frequencies from playing through those speakers, since the P.O. had subs, it makes sense to block what the subs play from the other speakers. I'm not up though on what value cap is used for what frequencies.
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
