Amp questions
Amp questions
Basically I would like to mount a sub in the trunk well and have the amp mounted below this and it would be completely enclosed my questions are
#1. is this a good idea to have an amp completely enclosed the main reason is due to heat as there would be no way to get fresh cool air around the amp
#2. if this would work is there a certain amount of cubic feet I should have around the amp
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Amp questions
the amp is likely to overheat, unless u can some how route some tubbing and fan to bring in air.. its brobly best to mount the amp in the spare tire compartment or the storage area if u want it consealed
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Amp questions
Here's what I did - and I'm having no heat issues - there's alot of space underneath for heat to dissipate:
https://www.thirdgen.org/forums/car-...mp-us-old.html
db057
Aug 11, 2015 10:11 PM
