Sub box question
Old Nov 1, 2009 | 11:25 PM
Zacks88's Avatar
Sub box question
The well box that I got I bought and the two 12in sub compartments are separated and i was wondering if I drilled a hole inside of it to feed the wires for the two subs through would it mess with the sound any? Probably a dumb question but I wanna make sure before I do it because I didn't think about building a box and I bought this one. Sounds like i got ripped off too cuz I paid quite a bit. Thanks in advance
Old Nov 2, 2009 | 12:40 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Sub box question
Do you mean through the separator between the compartments? It should be OK if you seal up the hole after running the wire through, use some silicone and let it set before installing the subs. Also, leave enough slack in the wires to connect to the subs before installation.
Old Nov 2, 2009 | 12:48 AM
hardon85's Avatar
I'm not exactly sure what your asking here, but I'm thinking you are asking about running the wires from outside the box to the subs themselves if that is your question just get some terminals like this http://www.tti-plus.com/Speaker-Box-...ti-bw-pts2.htm
If you paid a lot of money for this box I would recommend trying to get your money back. It is very easy to build a speakerbox I have built 3 of them and at the time I really didn't have much very many carpenter skills. As far as cost I believe the most I spent was $50. And in my opinion each of these boxes looked really great I wouldn't say completely professional because my carpeting skills have not been perfected yet basically around the port there is no real way to keep the carpet down by the port if you build a sealed box there would be no problems. You can spend more because you can buy some really awesome stuff for boxes such as built in handles really nice looking ports and corners and all kinds of stuff.
Another advantage to building your own box is you can build it to your speaker's specs like if it was designed for a ported or sealed box and the cubic feet etc, which in my opinion makes all the difference.
So if I'm understanding you rightyou bought a box without terminals if they slacked on this I imagine the rest of the box is not of terribly high quality. If so do me a favor and try to return the box and PM me and I can walk you through building your own box. I am by no means any expert at all, but my very first system I did was the very best system I ever heard as far as sound quality, probably not the loudest but it was hard on my ears to sit in there with it turned up and the bass did not drown out the treble at all.
On a side note I built 2 boxes for my 4th gen which sounded awesome both of which only had 1 sub and I think was still to much I guess I would recommend going with 1 sub because if you have never done a system before it's easier to set up (as far as wiring going from 4 ohm to 2 ohm etc), it is cheaper because you have one less sub to buy and you can probably get by with a little smaller amp and also you can build a box easier and stay in the speaker's specs size wise. this completely depends on the speaker but I had a cerwin vega that wanted 2 cubic feet which completely filled up my trunk well in my 4th gen. Let me know I would be glad to help
Old Nov 3, 2009 | 07:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Old Nov 3, 2009 | 12:05 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
if u are trying to wire the subs down, just do it from the terminals
Old Nov 3, 2009 | 01:29 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Drill holes to run the cable and leave them open.
They will act like ports giving you increased bass response.
Just make sure you run the cables with a testicular motion
Below is a graph that shows the increased bass response:
The blue lines represents the increase in bass.
The red line represents the decrease in cash.
The green lines represent the amount of weed smoked.Pretty steady I must say.*sips tea*
Old Nov 3, 2009 | 01:30 PM
Axle/Gears: Stock
Sorry I was just having some fun.
Old Nov 3, 2009 | 08:00 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
lol i hoped so, just making random ports makes the sub sound like crap
Old Nov 3, 2009 | 08:05 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Just letting you all know I still have the program I am giving away free to make subboxes. it shows what box you can make gives you the idea of what materials you need and also shows graphs of the freq. of the box for your needs. ect... FREE guys just pm if you want it. It is a rar file so you will have to extract it to get it to play it works on windows XP but vista ify. and might have to make sure you right click after install and put compatible for xp. Hoping it will let you do that.
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
