head unit help and yes i searched
Old Nov 27, 2009 | 02:42 PM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
ok guys i have a 1985 trans am with the stock harness cut. i went today and bought a nice bundled deal at best buy for a pioneer and some speakers. Well i wired it just like my old jensen deck was wired and nothing. Now mind you i had no memory on the jensen. There was no extra wire for the memory and when i put the red cable from the car to the red cable from the deck and then to the orange cable in the car my battery drained. So now i have it wired red cable from the car to the red cable from the deck and when i turned my car on it doesnt turn on. my old deck worked that way and this one doesnt. so please help.
Old Nov 27, 2009 | 02:45 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: head unit help and yes i searched
just run a power wire from the batt. it seem like its a common prob the constant stops working in camaros
Old Nov 27, 2009 | 06:04 PM
1986350's Avatar
Engine: 350 4bbl
yea if i did that it would drain my batt. just like now. Also me and my dad were looking and the deck only turns on if the constant is hooked up, then it drains the batt.????? this is getting old quickley
Old Nov 27, 2009 | 07:05 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
What do you mean it will turn on only if the constant is hooked up?
maybe a fuse is blown....look for a fuse that says CST or something or other in the fuse box on the passenger side...if its blown ur HU wont turn on.
Also...I have a HU that requires a cable being run from the battery and IT DOESNT drain your battery.The unit wont be drawing any current...you just connect the 12v to the cable u ran from the batt and the acc to the car harness n prestoooo
Old Nov 27, 2009 | 08:12 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
honestly 1986350; it sounds like you have both of those wires crossed... there are 2 cables (red and orange) one of them is connected to 12v AT ALL TIMES and the other is a switched (IGNITION) with the key is on. Connect the red from the head unit to the red from the wiring harness and the orange to orange and put the key in and see if anything happens. If it cuts on and maintains the memory (adjust the time) then everything is good. If it cuts on but does not maintain the memory then the wires are crossed...
Old Nov 28, 2009 | 01:16 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i think he should just take it too a shop. he sounds very inexperienced might cause more damage than good
Old Nov 28, 2009 | 09:54 AM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
you may have a car wiring problem or is it possible that you are doing it wrong although I suspect you are meticulously following every instruction to the T.
Have you tested all the relevant wires with ignition both on and off?
If you have and you still get battery drain...then it's highly likely that you have a vehicle wiring issue.
You may just have to create your own wiring to eliminate the draining issue.
Would not be the first time I had to do new wiring.
I have not gotten into mines yet...but soon I will be.
Good luck with it man.
Ghettobird52
Jul 5, 2024 11:18 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
ZsTransAm
Aug 11, 2015 07:30 PM
