Installing Stereo
Old Dec 28, 2009 | 01:23 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Installing Stereo
I just got a stereo off an 1990 oldsmobile. It was a junker i had lying around so i just cut the harness way far back in there so i could see what wires go where. Tomorrow i'm going to start installing it and i was wondering if theres anything i need to look out for? Are the wires color coded? Is it plug and play? And worst case scenario how much would it cost to get it installed? Thanks so much.
Old Dec 28, 2009 | 08:14 AM
vette gator's Avatar
Car: 85 Z28
Re: Installing Stereo
I'm not specifically familiar with Oldsmobile radios, but I would be surprised if it's not plug-and-play. If it isn't, there are adapter cables you can buy that plug into the car's harness and then into radio. These are all color coded, so it's just a matter of crimping together wires to build your adapter harness. Even though it costs a few bucks, I would definitely go this route rather than cutting the wires in your car. It will be 10 times easier to change radios down the road (if you want) and to work on the electrical system if you go the adapter route. Apart from this, it's a pretty simple job to install.
Old Dec 30, 2009 | 06:03 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Hope this helps.....
1990 Oldsmobile Cutlass Ciera Stereo Wiring
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
1991-92 Chevrolet Camaro Stereo Wiring
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Old Dec 31, 2009 | 06:45 PM
JackRs's Avatar
Car: 1991 Camaro RS
ok it looks exactly the same except for front speakers.
Does that mean i can wire it up myself?
Called a local shop and they want 60$ to fix it?
How easy would it be to install?
Old Dec 31, 2009 | 08:08 PM
Car: 85 Z28
If the plug in the back of the radio matches the ones in the dash, plug it in and put the screws to mount the radio and you're done. If the plugs don't match, check the Crutchfield web site for the plugs to adapt the Olds type to the Chevy type. If you have to go this route, one plug will be female and will fit the plugs in your dash harness. The other plug will fit the Olds radio. The other end of both plugs will be colored wires. Just join the same colors with crimp fittings (red to red, black to black, purple to purple, etc.). Plug the dash harness into you new adapter, then plug the other end into the Olds radio and you're all set.
Old Dec 31, 2009 | 09:07 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
do you have any pictures of this oldsmobile radio?
keep us posted on your progress
Old Jan 1, 2010 | 12:39 PM
JackRs's Avatar
Car: 1991 Camaro RS
Going today to install it will get pics
Thanks guys!
Old Jan 3, 2010 | 02:45 AM
JackRs's Avatar
Car: 1991 Camaro RS
Didn't get around it trying to install it here are some pics of the radio.
What do the numbers mean?
Printed out the key that Project listed for pocket reference is this the same thing?
As far as how i will do it.
I'm assuming just to strip the wires already in the harness and connect them with electrical tape and maybe some wiring tubes.
Will this work? Any specific order i should connect them in?
I figure i should at least try to save myself 60 bucks.
And a little off topic but is this a good radio? Thanks!
Old Jan 3, 2010 | 08:39 AM
Car: 85 Z28
It's pretty hard to see from the pictures, but are the wires going into the back of the radio hard-wired in or do they plug in? If they plug in, do the plugs match the ones already in your car?
Old Jan 3, 2010 | 08:55 PM
JackRs's Avatar
Car: 1991 Camaro RS
It goes into the HU with a plug, but the plug cant be removed at least i dont know if it can.
Old Jan 3, 2010 | 09:04 PM
Drew's Avatar
Pull that orange tab out, and then press the release clip and the harness should unplug.
Old Jan 15, 2010 | 12:30 AM
JackRs's Avatar
Car: 1991 Camaro RS
Update***
Well, after about a week of headscratching and googling.
The PO of my Rs decided to cut the wiring harness, its butchered.
So i'm going to take it to a professional.
I dont like the idea of doing it but i dont want to mess up my girl.
Old Jan 15, 2010 | 08:21 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
I have a question. Why would you put a 20 year old radio in it when you can get a new good head unit that does MP3, ect and will sound WORLDS better for $150 including harness and kit to fit in in the place of the original radio?
69 Six Pack
Oct 5, 2015 07:51 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
