Amp/Sub thoughts,advice,input thnx
Old Jan 3, 2010 | 07:14 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
So i picked up a Brand new Alpine CDA-9886 Deck as well as a set of new Type S speakers for front and rear.
now ive had subs that where way overkill before and just want a single 10 inch to give it some exta bump when the mood strikes. I plan on using a fairly thin sub and laying the box down on the area above the gas tank in my camaro, instead of down in the area that is lower.
Ive been looking at the 10 inch Alpine type S sub which is fairly thin and seems to be for the most part what im looking for, and would like a Alpine amp as well. nothing crazy just enough for the one sub.
also saw a 10 in kicker comp i belive in a perfect sized boz for 50$ at the local pawn shop, was contemplating that.
Anyone have any thoughts?
Old Jan 3, 2010 | 11:46 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: Amp/Sub thoughts,advice,input thnx
Cant go wrong for those $50
Old Jan 4, 2010 | 01:56 PM
Drew's Avatar
I'd go for the bottom of the well. Anything on the package shelf that's not bolted down is going to slide around. Since the gas tank is directly under the package shelf there isn't really a safe way to bolt anything down there. In the bottom of the well, there isn't really anywhere for it to go. Not to mention, passersby can't see down in the well, reducing the chance of theft.
Old Jan 4, 2010 | 02:14 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
i hear yea, ill be droping the tank during the rebuild so ill be able to throw in something if i really needed. as for the passerby itll be tinted out and with how over the top the projects gonna be itll subject to that anyhow lol.
i found the type S sub on ebay new for cheap and a decent alpine amp to so im leaning that way
Old Jan 5, 2010 | 07:56 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
A single 10" sub box could easliy be made to fit in the very bottom of the trunk in the space between the bottom and the ledges on the sides (what the spare tire panel sits on).
You would still have enough room to have a useable trunk.
TheTraut88
Sep 11, 2015 05:16 AM
TheExaminer
Sep 6, 2015 11:40 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
z28guy134
Sep 1, 2015 11:50 PM
