Ideas please for new stereo system
Old Jan 26, 2010 | 06:57 PM
Camaro87Z's Avatar
Car: 1987 Z28
Engine: 350 L98 interals with Roller Cam
Transmission: T5 Borg Warner non world class
Axle/Gears: 373 posi
I have an 87 Camaro just removed the bose system a year ago, and need some ideas on what would be a good route to go that isn't super expensive. Is it easy eliminating 4x6 in the dash? What would be a good 4 channel amp for speakers? Since mine was a bose system there is no speakers in the sail panels any ideas on how to put speakers into the sail panel area? Need help.
thanks
craig
Old Jan 26, 2010 | 09:48 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Ideas please for new stereo system
whats your budget? expensive is a relative term.
Old Jan 26, 2010 | 09:55 PM
Camaro87Z's Avatar
Car: 1987 Z28
around $700
Old Jan 29, 2010 | 04:23 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Is the $700 fjust or four speakers and a amp?
Do you want a sub?
If you eliminate the dash speaker location, where do you plan on mounting the speakers?
What head unit are you running?
Mounting speakers in the sail panels is not difficult...just need to be handy with a dremel.
Old Jan 29, 2010 | 04:39 AM
Pierced_Zombie's Avatar
Car: 1984 camaro z28
Engine: 305 H.O.
Transmission: 700r4 automatic
thanks
craig
mine wasnt bose but the guy b4 me saw to removing the sail panel speakers XD, anyways SEARCH the forums for how to upgrade ya dash speakers. go to your local pawn shop. with 700'$ you should be able to walk out with 2 systems XD
Old Jan 29, 2010 | 07:24 AM
Camaro87Z's Avatar
Car: 1987 Z28
No, I right now dont have any speakers in the dash(only have speakers in the kick panels and my deck lid in the back), I want to put speakers in the dash, basically im looking a good set of speakers for the dash and a good set of speakers for the sail panels dont know what fits and what would be a good product to go with, as for the amp I need a good four channel to get loud and clean sound out of the speaker. As for the deck i have that alpine ipod only deck, so far im not happy with it so thinking of changin that but no need for help on that one, as for a sub - not thinking of doing that at this point in time. Just need some good ideas on them speakers and the amp.
thanks
craig
Old Jan 29, 2010 | 09:39 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can add the sail panel speakers by installing the speaker mounting brackets for 6x9's from a donor car but you'll have to cut out the plastic behind your sail panel cloth. A better pair of 4" speakers can be installed into your kick panels and wired direct. That Bose amp in there won't do much compared to a modern decks output alone. I put little Kickers in mine. Used a dremel to clearance the inside of the boxes. My '87 Bose had dash speakers installed (they were aftermarket) but it had the factory wiring to them. Don't know if the Bose system had the 4x6's in the dash factory or not.
Does your Bose headunit work? Looking to get rid of anything?
Old Jan 29, 2010 | 02:46 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i have a kicket kx700.5 for sale. for 120 shipped. have a link of it on my sig
69 Six Pack
Oct 5, 2015 07:51 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
