Sail Panels
Old Feb 1, 2010 | 12:37 AM
Camaro87Z's Avatar
Car: 1987 Z28
Engine: 350 L98 interals with Roller Cam
Transmission: T5 Borg Warner non world class
Axle/Gears: 373 posi
Sail Panels
Can anyone help give me in depth info on what goes into cutting in and putting speakers into the sail panel area?
thanks
craig
Old Feb 1, 2010 | 07:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Sail Panels
You shouldn't have to cut anything to get speakers into the sail panels, as these cars came with 6x9s (well, most of them) to begin with. Have you removed the sail panel covers yet? Some speakers may require you slightly enlarge the opening, but nothing major.
Old Feb 1, 2010 | 07:45 AM
Camaro87Z's Avatar
Car: 1987 Z28
Re: Sail Panels
ya I removed the sail panel and all there is is the bare sheet metal no openings for the speakers to be put into, I think it's because that I had high end bose system that some of these cars came with from the factory.
Old Feb 5, 2010 | 07:08 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Sail Panels
You have a pic?
Old Feb 5, 2010 | 07:06 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Sail Panels
i have seen some early thirds with base radio that had
a black plastic panel there instead of speakers-the
plastic panel was fairly thick(about 1/8"),so could use
as speaker mount after speaker hole cut in
Old Feb 5, 2010 | 07:32 PM
Drew's Avatar
Re: Sail Panels
Is the plastic trim panel solid or is there a steel panel bolted to the car under the trim? If it's just a plate bolted in you can get 6x9" mounting plates out of just about any other Camaro/Firebird and bolt them in.
Old Feb 5, 2010 | 09:05 PM
Car: 89 IROC
Re: Sail Panels
My NOS panels came without any rear speaker cutouts but the plastic wasn't any thicker...just minus the cutout for the speaker opening and holes for the cloth sail panel to secure into.
Kinda like the clean look.
Old Feb 5, 2010 | 09:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Re: Sail Panels
the base radio '82 i had seen did have the openings cut
out on the interior paneling and had the cloth sail panels
in place,but just had the black plastic blank-off panel
mounted with screws in place of the stamped steel
bracket that holds the 6x9s on the cars with better radio
so real easy to install 6x9s on cars that did not come
with sail speakers
never seen what bose cars have there though
Old Feb 8, 2010 | 09:25 AM
Camaro87Z's Avatar
Car: 1987 Z28
Re: Sail Panels
thats what mine looked like now that i think about it (car is in storage)
Old Feb 8, 2010 | 09:26 AM
Camaro87Z's Avatar
Car: 1987 Z28
Re: Sail Panels
You have a pic?
So im guessing if i went all the way and take out the panel there would be somethin behind there.
Old Feb 8, 2010 | 09:47 AM
Drew's Avatar
Re: Sail Panels
If it were me, I'd pull the uncut panels and put them in storage, then pick up a set of junkyard panels that are already cut for rear speakers. Chances are you'll never want to go back, but if you do it'll be nearly impossible to find the solid panels.
Old Feb 8, 2010 | 10:10 AM
Car: 89 IROC
Re: Sail Panels
Yes there would. The pass. side would be the easiest to remove (as the panel is smaller).
Up to you if you want to cut the openings or get a used panel and keep the ones you have.
The solid panel isn't rare but I don't run rear fill so it's not a big deal to me.
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
formula00ra
Sep 28, 2015 11:50 AM
