Quiet my ride
Old Feb 7, 2010 | 08:09 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Quiet my ride
I'm looking to quiet my ride down from outside noise. I'm trying to do this on a budget and not looking to spend thousands of dollars on material.. Is there a way i could spend a few bucks and just cover everything or maybe just major spots? I'm also thinking of getting rid of that cotton material that is suppose to be the stock dampener, but still use the stock carpet.
Just want to know what everyone would suggest and give their opinions of what they use. I want to get rid of most of the sound if possible. basically alot more than what the stock dampening is... because its pretty bad imo.
thanks,
regards,
Timinsk
Old Feb 7, 2010 | 10:34 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Quiet my ride
second skin is very well priced, and is one of the best performing deatners out there
Old Feb 8, 2010 | 06:26 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: Quiet my ride
Im using Stinger Roadkill....a tiny bit thicker than Dynamat and cheaper...works great for me..
Old Feb 8, 2010 | 06:31 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Quiet my ride
I used peel-n-seal, you can get it at lowes or home depot. It took me about 4 rolls to do the entire floor and area behind the rear seats. At 15 bucks a roll it's pretty cheap.
http://tinyurl.com/ydfrttn
Old Feb 8, 2010 | 08:07 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Quiet my ride
Ward did you notice a difference at all? and did you put the cotton dampener on top as well?
Old Feb 12, 2010 | 02:59 AM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: Quiet my ride
I used fat mat if u really wanna go cheep..... i dont recommend but some people use that expanding foam stuff and if u only buy a lil matt the wheel wells are good places to start
after that maybe do the floor or the trunk part but wheel wells are usualy the big one man
Old Mar 16, 2010 | 02:00 PM
88birdttop's Avatar
Car: 1988 firebird
Engine: 350 and a holly finally
Re: Quiet my ride
i've seen some good things on other sites about frost king ducting insulation u can get it at lowes and other home improvement stores
http://www.lowes.com/pd_28929-1410-F...1449&Ntt=frost king duct&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=frost king duct
Old Mar 16, 2010 | 04:27 PM
Brad5117's Avatar
Re: Quiet my ride
i have a classic industries catalog for firebirds and they have deadner for 60 includes like 7 pieces which should cover pretty much everything , im purchasing here soon i could send u pix of it installed ??
Old Mar 19, 2010 | 08:54 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Quiet my ride
Be advised that some of the cheaper roofing material tends to smell in the car.
I wouldn't advise removing the factory material unless you plan on replacing it with an actual noise reducer material (as opposed to a sound deadener like Dynamat). Some is better than none.
Where are you noticing the "noise" coming from? Is it "noise" or rattling?
What's your budget?
Old Mar 22, 2010 | 11:21 AM
vengetta82's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
Re: Quiet my ride
how much is on a roll?
Old Mar 25, 2010 | 10:09 PM
bradwulf20's Avatar
Car: 91 camaro RS
Engine: 305 carbeurated
Re: Quiet my ride
i second the stinger road kill my friend has an audio shop and that is what he uses not sure on the price
Old Mar 31, 2010 | 04:55 AM
MrMaro92's Avatar
Re: Quiet my ride
it sounds stupid but for like 5 dollars a can u can buy rubberized undercoating it took 4 cans to do the entire floor and sail panals in my 92 and i have straight 3 inch side pipes and i can really tell a difference you can try that
86White_T/A305
Mar 6, 2016 01:48 PM
Linson
Sep 21, 2015 01:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
dimented24x7
Sep 6, 2015 03:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
