Audio noob here, few questions
Old Feb 17, 2010 | 09:46 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Hey guys,
I am interested in putting in a system into my car. I have browsed these forums and have learned a lot, but I am still unsure about a few things...
1. The first thing I believe I need is a deck...(iPod plugged into cassette adapter is horrible...I have to hit the deck sometimes to get it to work....). One thing I don't get though, I go to places like Best Buy, and I look at all the decks, and they are like....half the size of the current deck in my car?
I was told they will fit but....what will happen to that extra space above the deck? Is there anything to like...fill it?
2. How hard is it to wire a deck? Do I have to buy some sort of wiring harness SPECIFIC to a Firebird? Should a professional do it?
That's all for now, thanks
Old Feb 17, 2010 | 09:50 PM
JaxJags's Avatar
Re: Audio noob here, few questions
The stock Delco unit is 1.5 DIN. The head units you probably saw at Best Buy were 1 DIN. When using a kit, they look fine. Some tend to stick out a bit.
Look here for some examples.
Old Feb 17, 2010 | 10:11 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
when i wired mine, i just used the included harness and used this diagram: 89-92 Radio Diagram
also, for info on how to properly connect the wires:
proper wireing
Old Feb 17, 2010 | 10:21 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Thanks guys
So I can look for a kit on the internet to convert my 1.5 din to 1?
Old Feb 18, 2010 | 11:13 AM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Originally Posted by Skyset
Thanks guys
Not to convert....think of it like a frame that will cover the 1.5 din and leave you with a single din opening...
heres what you do...
http://www.metraonline.com/
go there...select your car... and then from the drop down menu select kits..
look for the model number,type that model number on ebay and there u go...
you dont HAVE to buy that kit...but thats what I use and works just fine..
Old Feb 18, 2010 | 04:16 PM
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
go to cruthfield.com theres is a tab under car audio section called "outfit my car" put your year make and model. get a dash intallstion kit. and a wire harness. its easy everything should be color coated from your new adapting harness to your HU. if you feel uneasy with this. find the wire diagram on your HU (should be with the box,papers,or on the HU itself) and then look at the wire diagram on your harness.
Old Feb 18, 2010 | 04:48 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Hey guys,
Yes the new decks will fit but you do need an adapter kit.
You have two options. You could buy a humount plate or a cheaper adapter. The one in the pic below (right side) is a Scosche (part number GM1516B).
You also need an adapter to plug into the back of your wiring harness that will mate up to the aftermarket unit. The one in the pic below (left side) is a Scosche (part number GM02B). Wiring instructions are on the back of the package.
What is your budget and what do you want fro mthe system? Do you want one or multiple amps? How many subs? What kind of music do you listen to? These are the questions you need to answer so you are happy with the system you buy.
Old Feb 26, 2010 | 01:01 PM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
They fit fine in my camaro how they come, but if you do have extra room, you can buy a dash kit specific for your car from wal mart or best buy, or really anywhere that has car stereo stuff for like 10 bucks, I had to do that for my Toyota and my girlfriends van lol. It should come with a wiring harness, I just get heat shrink from wal mart and snip the wires, and put them right ones together. It's not too hard, the first time might take a little while but after you do it once putting in stereos is easy. You could use electrical tape if you don't wanna buy heat shrink, but i wouldn't recommend that, unless its just temporary
Old Feb 27, 2010 | 05:51 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Walmart adapter 15 bucks easy to install just look for the adapter that says 88 and up general motors and look on the back at the list and find your car's model and year and same thing for the harness easy to do
Old Mar 12, 2010 | 04:04 PM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Here's mine, its a Pioneer DEH-P3100UB. Its nothing special but its better than the stock one by a long way. I was having a problem with the deck sticking out a little as you can see in the pic but fixed it soon after I took the pic.
Old Mar 15, 2010 | 02:25 PM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
if you go to best buy pick out a head unit that is ipod ready and have them install they will have the parts and everything you need. If my memory serves me correct from mine it will be about 100 bucks after everything is and they can run the cable for the ipod to your center console or glove box then you control with the radio. i would roll with a pioneer. that is usually the easiest to use. I used to sell equipment for best buy and tweeter and install on my own now.
Old Apr 7, 2010 | 10:45 PM
mongoosekeith's Avatar
in the case of ipod i would take out the ash tray and make a shelf in the area ind it would be hidden and close at hand but that is just my
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
