2nd Battery
Old Mar 31, 2010 | 04:19 AM
phlipdawg's Avatar
2nd Battery
Hi, I'm sure this has been done, and discussed but can't find any information on it. I have a 1989 GTA and I'm in the process of installing my audio system, I'm fairly sure I am going to install a second battery but do not want to place the battery in the rear of the car. I know the air cleaner and vaper canister can be removed and there is already a battery tray under them for the second battery. I'm not sure where to relocate the air filter, I know I can get a K&N setup right on the TPI unit. Is there anyone here who has placed a second battery on the passenger side of the engine bay?
thanks
Old Apr 4, 2010 | 05:53 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 2nd Battery
I ran a second battery when I competed in car audio many moons ago. The canister can be moved and secured right beside the second battery.
If you want to keep the ram air effect of the TA you could go real cheap and use aluminium dryer ducting to reroute the air filter below the battery tray. OR you could make a template out of dryer duct and have a muffler shop rebend it with 3" exhaust tubing.
Old Apr 5, 2010 | 06:00 PM
tevemithTA's Avatar
Car: 1992 TransAM
Engine: LB9 305 TPI
Transmission: MK6 5 Speed
Axle/Gears: G92 3.42
Re: 2nd Battery
A Second battery is a cool idea. If you use a marine type i think you can put inside car, however a 1 Farad (or even .5) capacitor will deliver high amounts of current, quickly as needed and can be mounted close to the amps so there is less wire involved, shortening that time it takes to get power to the amp. You'll get that punch you're looking for. Update the alternator and the baddest battery in the stock place and won't have to worry bout other mods. Be careful with install cause the capacitor needs to be discharged first if they're not shorted while in storage.
Old Apr 5, 2010 | 08:02 PM
slow305rs's Avatar
Re: 2nd Battery
Look at the Optima yellow or Blue top batteries and don't forget you'll need an isolator as well if you run two batteries.
http://www.woofersetc.com/p5297/SGP3...y-Isolator.htm
Ummm.....that's not what a capacitor does. A capacitor has limited advantages. 99% of the time they are just a waste of money.
Old Apr 7, 2010 | 12:39 AM
tevemithTA's Avatar
Car: 1992 TransAM
Engine: LB9 305 TPI
Re: 2nd Battery
thanks
I should have asked and not assume... What is the purpose of the second battery? If you are trying to achieve clarity and higher definition of sound, a farad capacitor is a viable option. If you just need power power power, to supply to the amps and you're strobing out oncoming traffic with your headlights.. you are deaf. hehe. Buy good speakers that are efficient and high power class A amps and you are golden. (proper wiring of course)
Here you will find further discussion.
http://wiki.answers.com/Q/How_do_you...or_to_your_amp
Old Apr 7, 2010 | 02:14 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: 2nd Battery
lol really a class A amp? efficiency and class A dont go together. im sure you meant class D
Old Apr 7, 2010 | 03:26 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Re: 2nd Battery
Class A amps are the LEAST efficient amps. And also capacitors do almost Nil in regards to helping you out unless you have almost no voltage drops. Caps are best used in sound quality installs to help clean up the peak signal.
Also when adding a second battery it's also important to have an upgraded alternator. Stock alts aren't going to like trying to charge two batteries.
Old Apr 8, 2010 | 10:54 PM
tevemithTA's Avatar
Car: 1992 TransAM
Engine: LB9 305 TPI
Re: 2nd Battery
on the contrary, I meant more efficient transducers or drivers.
Old Apr 9, 2010 | 02:04 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: 2nd Battery
? you told him to buy a high power class A amp, when is currently having problems with what he has...
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Lbibb
May 5, 2016 12:00 AM
drumstixer
Sep 29, 2015 03:02 PM
