Is this going to run my battery down?
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
I just wired up a stock radio in my camaro. The way it's wired the radio it's self will be off but the clock will stay on even when I turn the key off. I know I could change that, but I would prefer it. Is that enough to drain my battery? I'm pretty sure I've seen other people with vehicles that do this.
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: Is this going to run my battery down?
no, you should be fine. pretty much every car is wired that way to save the radio presets and the clock.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if it's a stock radio with lighted digital display,that will
run your battery down after a day or two-i once hooked
up my '84 delco head unit so the clock would remain
lit and i found it would run the batt low after 30 hrs or
so,i checked the current and found it was pulling about
1/2 amp with the clock lit.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
