Radios with same mouting brackets?
Old Jun 25, 2010 | 02:24 PM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Anyone have any suggestions of other cars that possibly have the same mounting brackets on the radios as our cars do?
I finally found and bought a radio to match the RPO codes for my car, but the place I bought from didn't include the mounting brackets that go on the side of the radio. Unfortunately it's been so long since I've played around with audio systems in these cars that I don't even remember what those brackets look like.
Old Jun 26, 2010 | 07:49 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Radios with same mouting brackets?
Just about any late 80s GM car uses the same mounting.
Old Jun 26, 2010 | 08:17 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Yeah they are held on by a nut that attaches to a slide clip
Old Jul 18, 2010 | 10:11 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Would anyone happen to have any of the brackets available for sale?
I went through the entire local junk yard, and there wasn't a single car that that still had the radio in it with the correct brackets.
Old Jul 18, 2010 | 01:29 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Hmmmm..............I have my old Delco am/fm right here!
Did you get a Delco replacement thats the same dimensions as the stock one?
Does it have the bracket on each side toward the front of the radio?
OR the brackets are missing?
Like MY suggests it is just a L bracket thats held on by a speed clip and nut.
That then bolts into the radio opening...............
Anyhoo if that what you have and the brackets are what ya need give me a shout and I will send them to ya................
BUT you will owe me a cold beer ! LOL!.................geo
The bracket mounts here:
Attached Thumbnails Radios with same mouting brackets?-radio_bulb_replacement6.jpg
Old Jul 18, 2010 | 02:32 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
I can tell you one thing to help you, the 85-92 brackets are very different from the 82-84 ones because of the different center console : the holes are in a different place, they're longer with a crease at the top. I guess the Camaro brackets are the same as the 82-84, as well as the Fiero brackets.
They're symmetrical so they're both different parts, this is what you're looking for : 10098503 (right) and 10031618 (left).
Old Jul 18, 2010 | 04:03 PM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Ok, so I found a place that sells the right side, but I can't find the other anywhere.
These are pictures of the sides of the radio I have. It's suppose to be the radio matching the RPO code (I think UM7). And as you can see, I don't have the retaining bolt for the bracket either.
Attached Thumbnails Radios with same mouting brackets?-hpim0202.jpg   Radios with same mouting brackets?-hpim0203.jpg
Old Jul 18, 2010 | 05:52 PM
my82roc's Avatar
I have a pair of universal mounts and also a pair of side specific.Complete with slide clips and nuts
Attached Thumbnails Radios with same mouting brackets?-img_1382.jpg   Radios with same mouting brackets?-img_1381.jpg
Old Jul 19, 2010 | 04:49 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
my82roc,
The part numbers from the other post show the brackets you have pictured on the left, but I can't for the life of me figure out what that extension at the top of the bracket with the notch would be there for.
But it appears as though the holes for the screws are the same distance away on both brackets.
Wouldn't suppose you'd be willing to part with a pair of those brackets?
Old Jul 19, 2010 | 06:22 AM
my82roc's Avatar
Yeah I'd part with a pair
Old Jul 19, 2010 | 11:17 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The clip with the nut slides into the slot in the radio body.
I have the same brackets in the pic on the right that My posted.
Solar was correct!
Old Apr 5, 2011 | 08:11 PM
SoTexZ28's Avatar
Car: 88 Camaro IROC-Z Convertible
Transmission: 700R
Did you send both sets of bracets to Vachaum? I need the ones on the right. If you still have them, please let me know
Old Apr 6, 2011 | 06:23 AM
my82roc's Avatar
Yes I still have that one pair
Old Apr 6, 2011 | 06:34 AM
SoTexZ28's Avatar
Transmission: 700R
Are you willing to part with them? If you are, I live in 78572, please give me a price.
Old Apr 6, 2011 | 05:56 PM
my82roc's Avatar
10 dollars shipped
Old Apr 6, 2011 | 06:32 PM
SoTexZ28's Avatar
Transmission: 700R
10 dollars shipped
Will those fit on my '88 IROC?
Old Apr 6, 2011 | 06:36 PM
SoTexZ28's Avatar
Transmission: 700R
Can you please measure the space between the two holes, that way I'll be sure they fit my '88 IROC. Do you have paypal?
Old Apr 7, 2011 | 12:31 PM
my82roc's Avatar
They are the exact brackets that came on the factory radio.Its approx 1 1/4 inches between the 2 holes.Yes I do have paypal
Old Apr 7, 2011 | 05:55 PM
SoTexZ28's Avatar
Transmission: 700R
I send you a pm so you can send me a paypal address. I will send you my home address when I deposit the money.
Old Apr 11, 2011 | 09:17 PM
SoTexZ28's Avatar
Transmission: 700R
Were you able to mail the bracket? If so could you give me a date they were mailed out?
Old Jun 28, 2011 | 02:50 AM
86 thunder cat's Avatar
HEY IM LOOKING FOR A FACTORY RADIO FOR MY 86 CAMARO CAN ANYONE HELP ME OUT (281)690-9571 THANKS
RS Reaper
Oct 17, 2018 07:52 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
