Radio, weird static?
Old Jun 27, 2010 | 04:11 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
My radio has this really weird issue.
The radio will work fine all day..every speaker works everything..but when i put the car in the garage for the night and start it the next day there is non stop static for a good while..
I have to like ride around id say for a good hour before the static goes away and the car radio plays normally.
What could be causing this? i checked all the cables behind the radio and everything seems to be good to go no real exposed wires nothing..
Thanks for the help
Old Jun 27, 2010 | 05:32 PM
RyanEricW's Avatar
Re: Radio, weird static?
Do you have a "pop" noise when you first turn on the radio?
Is anything radio related (headunit/amps) sharing the same ground? If so, separate them and see if that alleviates the problem. IF everything looks good, and problem persists, try another head unit to be sure.
Old Jun 27, 2010 | 05:36 PM
Car: 1986 Iroc-Z
Engine: 355
Nope no popping noise just plain static its weird because it only happens when i park the car for the night in the garage..other than that it works fine.
Old Jun 27, 2010 | 05:51 PM
RyanEricW's Avatar
What about the grounds?
Old Jun 27, 2010 | 05:54 PM
Car: 1986 Iroc-Z
Engine: 355
No grounds are sharing =\ could it be an antenna issue or something.
The antenna cable seems brand new so i don't know..Faulty radio? ill know for sure when i replace my current one.
Old Jun 27, 2010 | 05:56 PM
RyanEricW's Avatar
Yeah weird issue, sorry I couldn't give you a definite answer. Only thing I can think of try swapping with stock/another radio to test it, that is how I would do it.
Old Jun 27, 2010 | 05:58 PM
Car: 1986 Iroc-Z
Engine: 355
ill give that a try thanks for the help.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
db057
Jan 10, 2020 08:55 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
