UQ7 Replacement
Old Nov 11, 2010 | 11:36 PM
TPI86TA's Avatar
Car: 88 GTA
UQ7 Replacement
Can you simply swap out those rear speakers for 6x9s? Or do you need a special bracket or anything to make it work? Anyone ever do this? Any advice would be appreciated. Thanks guys.
Old Nov 13, 2010 | 12:31 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: UQ7 Replacement
the sail panel opening is the same-you can take the 6x9
adaptors from a junker or make your own out of plastic,
sheet metal,or other material-i have seen base cars that
had a plastic panel in place instead of a speaker panel.
Old Nov 14, 2010 | 02:19 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: UQ7 Replacement
If you have factory 6x9's in the back, aftermarket replacement 6x9's will fit with no problem.
Old Nov 15, 2010 | 04:59 PM
TPI86TA's Avatar
Car: 88 GTA
Re: UQ7 Replacement
Its all good, i cut some sheet metal and im in business now, thanks.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
