6x9s vibrating
Old Nov 28, 2010 | 07:31 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
6x9s vibrating
my 6x9s are vibrating like mad! is this a sign that the speakers are on there way out the door? they are sony explods and they are only about a year old, will be a year old in the spring.
Old Nov 28, 2010 | 08:01 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: 6x9s vibrating
Are your bolt tightened all the way? I had the same problem with my Pioneer 6x9s and I just took them out, and put them back in and problem was solved.
Old Nov 28, 2010 | 08:15 PM
Engine: L31 350
Re: 6x9s vibrating
hm, good idea, i havent thought of that...ill check this wedensday since ill be busy tomorrow and tuesday, thank you for that idea!!
Old Nov 28, 2010 | 11:59 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 6x9s vibrating
I had a pass side 6X9 vibrating. Bolts were tight, so I thought a nice new gasket would stop the noise, but it didn't.
Turned out the guilty party was the vibrating flap in the flow-through ventilation valve in the door jamb. I removed the valve, and soaked the rubber flap with Armour-All to soften it up. Then wiped up the excess with Q tips and re-installed.
All quiet now.
Old Nov 29, 2010 | 02:52 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: 6x9s vibrating
Also remember that it may not be the bolts that attach the speaker to the sail panel.
Upon further inspection, you will notice that the piece of metal the 6x9 is bolted to is also bolted to the sail panel by an addition 4 bolts. Make sure these haven't come loose.
Old Nov 29, 2010 | 05:23 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 6x9s vibrating
dynamat is your friend, mine rattled like crazy and i had every nut and bolt in that area tightened down hard, unfortunately it didnt work so i bought a wedge pack of dynamat and put it all around the speaker mounting area, top to bottom, and the left overs went onto the outer skin from the inside ( sub prepping) it works great, check hifisoundconnection, they have audiomat and its cheaper/thicker than dynamat is
Old Nov 29, 2010 | 07:55 PM
Engine: L31 350
Re: 6x9s vibrating
its really only my driver side speaker thats doing it, today when it was going off i put my hand on it and it stopped....if that helps
Old Nov 30, 2010 | 05:25 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 6x9s vibrating
Yeah dynamat will fix it, it just dampens vibrations like when you put your hand on it
Old Dec 21, 2010 | 11:17 PM
87TA305's Avatar
Car: 1987 Trans Am WS6
Re: 6x9s vibrating
I just stuck a little piece of speaker wire in with the bolt to give it a real snug fit, works like a charm keeping them from coming loose.
Old Dec 21, 2010 | 11:32 PM
87350IROC's Avatar
Car: 87' IROC
Re: 6x9s vibrating
All quiet now.
Agreed, its probably that vent. I put some foam gasket take around it to tighten the fit. Worked like a charm.
Old Dec 30, 2010 | 09:24 PM
Tishawn45's Avatar
Re: 6x9s vibrating
I need a pair of 6x9 speakers for the rear deck of my car. I need them to work with the Kicker amp and I want the best bass I can get without adding a sub, so which 6x9's have the best bass?
_____________
Search Engine Optimization
Google Results
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
