Need the best audio person in here!!
Guest
Posts: n/a
Ok well i am changing my headset because i don't like it and some of the buttons dont work and it is just plain out worn out.
I slid out my old one Looking at these 5000 WIRES! i know someone has a aftermarket setup but don't know how to use it. Please someone help me i need to add a new connecter to connect my new head unit.
This is a mess.
This is a mess.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Need the best audio person in here!!
Factory wiring colors.
1991-92 Chevrolet Camaro Stereo Wiring
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Car: 89 IROC
Is the faceplate broken? How was it before you removed the deck? The logic being if it was fine before you removed the deck, then something broke.
Car: 89 IROC
Sound like you might. Best to go see a stereo shop and see what they say. Good news is that new install kit is pretty cheap.
Car: 1987 Trans Am
Engine: LQ9/L92
you should have a cage that the radio slides in and out of. the cage needs to be installed into the dash kit (usually has some tabs that need to be pried up to hold it in place) and then the radio will snap into the cage. you can see the cage on the radio in the first photo (the slightly different color metal around the front half of the headunit)
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
