power problems to the deck
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
ok i have an aftermarket deck in my 1989 camaro. after hooking everything up i came with one problem. it would not turn on the radio unless the constant (yellow) and power (red) where stripped back and touching each other. this has been going on for a few months but i was to busy working on the engine to worry about it. now i have some time to go over it. i no that all the grounds for everything are good. i have tried tracing wires around but no luck or get lost in the cluster of wires under dash. it wouldnt be such a big deal except for the part where i have to re do the time and everything when i turn it on. also i have to untouch the constant and power wires to get it to turn off. thanks in advance for any help
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Problem Is Touch & Go
The problem is both wires need 12 volts for the radio to operate, and only one has it.
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) find which wire has no power.
If it’s the orange wire the problem is the ARC fuse, or associated wiring.
If it’s the yellow wire the problem is the RADIO fuse, or associated wiring.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning A Foot In The Opposite Direction?
Happy Racing!
Re: Problem Is Touch & Go
Hey, ok i i see an orange wire but i am not sure what it is for. i dont see it going anywhere. but i did take a test light, and my power wire to the radio fuse is good. so i ran a new constant wire to the battery and now everything works great. thank you
