radio equipment help
My 2 front speakers in my 87 seem to be going out so i need to buy some new ones, I would also like to upgrade a little bit because with ttops out its not that loud. Does anyone have any suggestions or help towards what i should do? I have an after market deck and would like to just replace speakers but if i have to, ill install an amp too.
Car: 89 Camro RS
Engine: 305ci
Axle/Gears: Stock
Re: radio equipment help
I dont have aftermarket speakers in my car, but i do have a Kenwood system in the back. I dont think that you need to install an amp for aftermarket speakers. I have ttops as well. And aftermarket decks add alot to ur speakers. It amps them up big time.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Get a nice aftermarket headunit, look at pioneer or kenwood. Usually the 150-250$ are the headunits you want.
It really helps to get aftermarket amps to power them, so much louder.
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Yes get an aftermarket head unit. And i replaced my dash speakers with Alpines,and replaced the wiring with thicker wire. And i added Alpines to the rear pillars as well. Nice and clean
Thanks for the replys i got a pioneer deck already so ill just grab new front speakers for now and see how that is, ill probably add new rear speakers and amp in the future
