Options for mounting subs behind back seats.
Old Jul 17, 2011 | 03:36 AM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I was thinking about mounting 2 12" subs right behind the back seats on top of where the gas tank is and put mount the amp either behind it right before the well starts. or beside it or something. Would they have to be shallow subs or would regular ones fit? Would it block my whole rear view mirror? And could i just velcro the crap out of it so i dont have to screw it in and possibly hit the gas tank? Any advice would be appreciative. Pictures of amps up there would be nice! Thanks!
Old Jul 17, 2011 | 07:13 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Options for mounting subs behind back seats.
Old Jul 17, 2011 | 09:19 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
that box doesnt look like it has enough airspace for those subs
Old Jul 17, 2011 | 01:26 PM
Engine: L31 350
youd be suprised lol
Old Jul 17, 2011 | 02:59 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I meant like on top of that hump. Like where your amp is located in that picture.
Old Jul 17, 2011 | 03:13 PM
travis401's Avatar
Car: 91 Camaro RS
thres not a lot of room between the hump and the hatch glass, and anythig you put there is going to obstruct youre field of vision behind you and is unsafe.
Old Jul 17, 2011 | 03:19 PM
onefast85's Avatar
Car: 85 camaro
Engine: 605in bbc
Transmission: powerglide
Axle/Gears: 12bolt with 4.10's
i use the well in my car as the box and to hide my nitrous bottle. ..board is screwed to the car and hinged,had 2 12's in it but used them in another car,fixing to buy some new ones.
Old Jul 17, 2011 | 03:54 PM
travis401's Avatar
Car: 91 Camaro RS
not a bad idea, but since the enclosure isnt sealed, youre loosing some of the thump. its a great cheap way to mount subs though.
Old Jul 17, 2011 | 08:08 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
You'd be doing yourself a dis-service by putting the subs where you propose.
With the design of the rear of the 3rd gen F-body, there is a natural gain in output and even arguably some quality. With the shape of the glass, and that hump, it makes almost a natural horn, that helps any sub system installed in the well, to seem more than what is really there.
As said, any sub enclosure sitting on the hump will obstruct your rearward vision.
Old Jul 19, 2011 | 07:15 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
completely agree, and will add that it would be a very dangerous projectile if you get in an accident. there is no good way to hold down a box on top of the hump because of the gas tank below. there are a few sets of plans kicking around these boards for a good well sub box, highly recommend going that route
Old Jul 19, 2011 | 04:50 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Thats my thought too! Dangerous in a collission...Velcro? Thats just crazy!
Old Jul 19, 2011 | 05:30 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
http://www.youtube.com/watch?v=n6zU1rNPKq8
Old Jul 20, 2011 | 01:05 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Now you cant use your T-Top bag anchor points. I have that same issue.
Old Jul 20, 2011 | 02:37 AM
Eh i dont really need it. I just put some of the bag under the box
Old Jul 22, 2011 | 07:52 PM
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
I'm thinking about doing the same setup as dylanjessy. I'll probably out the amp in the tire well. Not sure what subs to buy yet, or what amp but im working on it
Old Jul 22, 2011 | 08:08 PM
For a first set up,i suggest some Rockford Fosgate subs. And maybe a Kicker amp
Old Jul 22, 2011 | 08:31 PM
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
Yeah, I have been told to get some fosgates a couple of times. They're pretty decent price too. Amps are a lot more expensive. Ill probably get one off of craigslist.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
