speakers in the rear other than the 6x9s?
Old Jul 18, 2011 | 09:05 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
I have asked this before but didn't get a clear answer. Did the camaro ever come with stock speakers in the rear similar to the 4th gen? I wanna know factory options. I don't wanna fabricate something
Old Jul 19, 2011 | 07:12 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: speakers in the rear other than the 6x9s?
some cars that had the optional well cover got speakers in there, but that is not an easy add on, since you need new plastics and have to weld on additional mounting brackets. i used 6 1/2" speakers in place of the 6x9s and while that did require making a new mounting plate, it was a very easy thing to do
Old Jul 19, 2011 | 09:34 AM
Car: 02wrx/88 rs
So its not as easy as just changing plastics? I wish I could see a picture of this.
I would like to have 9 speakers total. Two dash, two in cargo area, two amp powered kick panel,and two amp powered 6x9 and a sub
Old Jul 19, 2011 | 09:47 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you're honestly better off getting 1 or 2 *good* sets of speakers then trying to put a ton of them everywhere in the car. too many speakers ruins the balance and sound stage and making tuning miserable. you can do loud and musical without needing that many speakers in the car
Old Jul 19, 2011 | 10:02 AM
Car: 02wrx/88 rs
Ok then what do you think about this, I already have infinity kappa 6x9 then what about kappa 4x6 and some kick panel speakers.? I like putting speakers in stock locations to keep them low profile
Old Jul 19, 2011 | 10:08 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
do up a good set of kick panel speakers (amplified) and forget about the dash ones. too small to really produce anything useful in the midbass to mid range. a good set of 6 1/2" in the kicks will make you much happier
Old Jul 19, 2011 | 10:31 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The factory Bose rear speakers were in this panel I found in a thread here on TGO:
https://www.thirdgen.org/forums/inte...bose-rear.html
And here is a 8" sub in the sail panel:
And a 10" sub with a 1" tweeter:
Old Jul 19, 2011 | 10:48 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I've been tossing around the idea of doing 8" subs in the sails, but not sure if I feel up to the challenge of properly sealing up those areas. I'll probably just stick to with a single 12 in the lower well area and call it a day.
Old Jul 19, 2011 | 10:53 AM
Car: 02wrx/88 rs
So that's where they go
Old Jul 19, 2011 | 10:56 AM
Car: 02wrx/88 rs
I once had a cheap(50 bucks for sub and amp) sealed 10 in the hatch area and it hit pretty hard. Ppl thought I had two 12s lol. But ever since that I want a sealed 10. Heard two 12s in a 4th gen but that was too much
Old Nov 9, 2011 | 01:36 AM
Gabe10's Avatar
Car: 91 RS
Engine: 3.1l
Also what you could do is put a pair of 5 1/4" speakers in the dash if you dont want anything getting in the way of your feet. Thats what I did and I am quite happy with the setup.
Old Nov 15, 2011 | 07:46 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Ironicaly both those cars at one point in time were mine, oh wait I still own the blue one
Old Nov 20, 2011 | 06:40 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I did a custom 8in woofer and was planing to do a sub woofer but talking with the pro he said its not enough space for a sub to breath and will over heat ad burn out so a 8 inch woofer would be better but he side it not much better than the 6x9 so a good 6x9 would be better its not worth the work.
Old Nov 22, 2011 | 06:00 PM
He is wrong, every sub has its own air volume and enclsure requirments, as long as you are within these parameters then they work perfectly good.
Biggest problem with mounting a 10" in there is the mounting depth, theres lots of air volume for a properly matched woofer
The 10's that were mounted in the 90 were actualy set to play more as a mid woofer, the car had four sealed 15" sub's that played the low base
In my 92 (blue car) those are 8" HERTZ mid woofers in the sides, I use two ported 10" W7's in the rear for my low base
Twin 6'5" in each panal is another od ball we have done around here, dont think I got pics off hand, I'll take a look around, that car ran three JL W6's across the back for the lows
personaly I dont like oval speakers and will always covert to a round if I can, I just plain beleive they sound better, I have been called a pro before, but maybe I am just a guy flapping at the gums, either way we all, even pro's, have our own opinions, you get to decide what you want put there
Old Nov 22, 2011 | 06:29 PM
Car: 02wrx/88 rs
I like my infinity kappa 6x9s plan on using infinity kappa componants in the front and a 10inch kappa sub with a kappa five 5channel amp.
Old Nov 22, 2011 | 06:53 PM
Sojer's Avatar
I race my car and I have 2 12s in my car bout to swap those out for some alpine type r's some new 6x9s and I hope I can drop and skrew in some 6.5 in the dash or something better than 4x6.
Old Nov 22, 2011 | 07:18 PM
lol, iv been known to hit the track on occasion :P
Well Sojer, the biggest we have ever put in the dash was 5.25", just gotta be carefull also on the depth available up front too, because some F cars the venting gets in the way restricting speaker selection even more
I'd suggest a good set in the kick panals and call it a day for simpicity, in my 92 I run HERTZ Space 6.5" in the doors, but that took abit of custom work to make it look kinda stock
We've ran 5.25" coaxels in the stock Bose kick spots too, the one side actualy fits in pretty good, the other took alot of custom work that I personaly dont think was worth wile, but if one is hoping to keep the stock look. Sorry I dont have pics of the "bad" side, go figure, lol
Same car ran 6" JL Woofers in the back Bose location, not enuff base in my opinion but the owner was happy and thats what counts, I just wasnt impressed with the output, or lack there of
Old Nov 23, 2011 | 07:23 PM
excessiveego's Avatar
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
My 90 has stock size Alpine type S speakers all the way around with two 12's in the hatch driven by a 300W single channel and the sound is clear and the subs provide decent bass, good listening quality as far as i'm concerned.
my 88 is going to be pro-street and not have the weight of a sub box, currently has stock size Boston acoustics in the back and 5" Boston acoustics in the front and sounds decent
Old Nov 23, 2011 | 07:29 PM
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
since were talking about speakers does anwone know where i can get a speaked box for a 91 vert?
Old Nov 24, 2011 | 10:13 AM
Car: 02wrx/88 rs
i really like what you did!
Old Nov 26, 2011 | 12:39 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
4×6 dash, 6×9 sail panels ( run off the deck)
6.5" in kick panels run off a 250 watt or higher amp,
2 10" subs in a bandpass box run off a 5000 or higher amp, stick with well known brand speakers, and you should be quite happy.
Reddeath210
Oct 6, 2015 08:20 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
zayne0
Aug 24, 2015 07:22 PM
89lsc
Aug 14, 2015 04:58 PM
