Antenna
Old Jul 21, 2011 | 02:19 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Antenna
I found a new really cool one at walmart that has a magnet on it, so it works better. It is larger then the factory one, so how hard of a swap would it be??
this is the potentiol new antenna
http://www.walmart.com/ip/Cobra-36-3...tenna/11974009
Old Jul 21, 2011 | 02:42 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Antenna
. Horrible choice man.
Old Jul 21, 2011 | 03:00 AM
Car: White 84 z28
Engine: Chevy 350
Re: Antenna
What do you mean?
Old Jul 21, 2011 | 04:48 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Antenna
Originally Posted by blue birdy 87
What do you mean?
Find a factory replacement in the yard or on ebay.
Stay away from the wal mart
Old Jul 21, 2011 | 06:08 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Antenna
Uhh, that antenna is for a CB.
Old Jul 21, 2011 | 07:57 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Antenna
people try and get the stubby attennas for these cars as it makes the car look better and slicker. why get a bigger one?
Old Jul 21, 2011 | 08:53 PM
Re: Antenna
My personnal preferrence is to stay OEM. Its bad enough to see a Firebird with Chrome 5 spoke IROC rims, which I have seen in San Bernadino CA. a few years back.
Old Jul 21, 2011 | 09:18 PM
Car: White 84 z28
Engine: Chevy 350
Re: Antenna
I dont want a salvage yard one or something like that, i have an ok ish antenna now, my goal is to get a stronger one so i dont have a much static (because my favorite local station is a little bit away)
Old Jul 21, 2011 | 09:29 PM
Re: Antenna
I was a Communications Specialist in the US ARMY. A "stronger antenna" is not your problem. Having a seperate or built in power amplifier will make a signal travel futher but it will not help with having a strong clean recieving signal. There are dead spots all over the world. You can stand about 10 feet infront of a high wattage antenna and not get a dang signal. Thats a dead spot. The air around us is littered with AM and FM frequencies. Along with am and fm frequencies is bluetooth, microwave, and extraterestrial signals from outer space. All these frequencies can and will affect a signal. So to combat a unwanted signal, you must have a good receiver and tranmitter. The electronic devices within a stereo of R/T (reciever, transmitter) are built by different companies. SOme companies make cheap devices to get the job done as well save money to capitalize in profits. So in this case its not the antenna, its the device that you are using. If you have a cheap electronic, well then, you get what you pay for.What you can do is petition and have many people stand behind you to have the broadcasting company build a retrans tower. This will retransmit the signal to a longer distance. Or you can have the FCC contact the transmitting company to see if they can increase the signal wattage in their transmitter antenna.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
