Need help wiring up Pioneer GPS unit in 87 TA
Old Aug 7, 2011 | 09:02 AM
mrrman's Avatar
I have a Pioneer Avic 1 unit and would like to hook this up in my car. I will be having dual amps and 6 speakers attached when this unit is running. My stk connector is shown and my unit has a blue connector to it. Is there some kind of adaptor to make this work together.
stk connector
back of Pioneer unit
blue connector on Pioneer unit
Old Aug 8, 2011 | 12:12 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Need help wiring up Pioneer GPS unit in 87 TA
someone completely hacked up your stock harness, so you'd be best to grab a harness end from a local junkyard and start from scratch. that way you can be sure that nothing is wired incorrectly and that you can change decks later down the road if you need to. from there, you can buy a factory harness adapter that will tie into the aftermarket radio's pigtail.
Old Aug 8, 2011 | 01:04 PM
mrrman's Avatar
yeah, I know its a mess....thanks for your suggestion...I will go that route
Old Aug 8, 2011 | 01:13 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
my TA's an 87 as well and I opted for a newer GM harness, like this:
in case you want to grab a stock deck replacement later, it opens up a wealth of newer units compared to the original design (which is here):
Old Aug 8, 2011 | 01:39 PM
mrrman's Avatar
Did you get your harness from a wrecker?
Old Aug 8, 2011 | 01:46 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
yup, we've got a couple of pick your own junk yards around here, so I grabbed my last couple for under $5 each. there are a few companies out there who make a new repair harness like this too:
http://www.metraonline.com/part/71-1858
Old Aug 8, 2011 | 02:01 PM
mrrman's Avatar
should I get a harness like the one you posted and just redo the whole thing so it mates to my Pioneer unit or contact then with what I have and get something made up
Old Aug 8, 2011 | 02:05 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i prefer to start with stock harness, only so that you're not stuck with rewiring everything again if decide to buy a new deck. wire in a factory harness, get your adapter, and go from there.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
stalkier
Dec 6, 2015 11:25 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ZsTransAm
Aug 11, 2015 07:30 PM
